Question about IBM ThinkVision L170 17" LCD Monitor
Monitor turns itself off
I just got it used and it worked fine at first. Then it turns off for no apparent reason. The power button seems to do nothing. unplugging and rebooting doesn't help
  • 20 Answers
What is the TYPE # on the side of the monitor?
There is a known issue in TYPE 6636-AC1 and the like of the internal power supply going out.
My company has replaced over 300 of them in the last year!
Posted on Jan 29, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
DS240WB worked fine but seems now not recognizing signal and fails to turn on
The reason why your monitor might not be recognizing a signal is because the graphics card in your pc might not be correctly plugged into a pci slot or your internal graphics may have a short somewhere. If the monitor turns completely off after it cycles Then it might be an internal problem with the backlighting in your monitor screen
Dec 07, 2013 | DoubleSight DS-240WB Monitor
When I connect power to my Dell E198FP monitor, the power button flashes green and there is a small chirping noise and it won't display anything. It will also not allow me to power on/off the monitor but...
This is a failure of the power supply in the monitor. It can be easily fixed by replacing a pair of failed 680 microfarad 16 volt capacitors. If you have a friend who is handy with a soldering iron they will be readily apparent as failed since the top will "bulge". I just put this monitor back together and didn't write down the designators, unfortunately. This is the second monitor I have repaired with this failure...apparently the value is not terribly critical, just don't use caps with a lower voltage rating. I actually just replaced them with a pair of 100 microfarad 50 volt caps since it was what I happened to have on hand and the monitor worked fine once repairs were complete.
Nov 16, 2010 | Dell E198FP LCD Monitor
Monitor control panel comes up for no apparent reason. Begins to rotate between options without any user input. If I hit the power button, the rotation stops, and the monitor remains on. Have already reset...
This sounds like a problem with one or more of the buttons on the monitor itself being stuck on, or a fault in the circuitry connected with the buttons.
Check for grit etc. in the buttons, maybe try cleaning with a soft brush while unplugged from power.
Apr 11, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor works fine until the sleep mode and then it goes blank. I have to unplug the power button and it does work again
It seems it is a motherboard battery problem. It most likely is not the monitor which is in "sleep mode", it is the computer itself.
When you cannot get a computer out of "sleep mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty. When your computer detects this battery is empty, it goes into a low-power mode. The solution is to replace the button-cell battery on the motherboard of your computer
If this solution works fine for you please rate this
Feb 24, 2010 | Dell E196FP 19" LCD Monitor
Philips LCD TV Matchline series keeps switching off!
heating up issue, try unplugging it and if you can clean the dust from within the unit. Try reversing the vacuum and blowing excess dust out.
Sep 09, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Gateway FDP1975W Monitor Power Button Not Working
i would advice you to take your monitor to a technician, but if you are not ready, please leave the monitor on and make sure it is connected to ups u can now turn it on and off from the ups, if you continue the menu, Auto fit etc stuff, you might damage or disorganize the settings of your monitor which might cost you more. thanks
Jul 17, 2009 | Gateway FPD1760 17" LCD Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Power on button on Tungsten E2 does not work
Potentially because of dust on button. Use star tool to take apart and canned air to blow out
Mar 28, 2008 | Palm Tungsten E2 Handheld
IBM ThinkVision L170 17" LCD Monitor Logo
185 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
