WIRING A SPL DK2-340 340 WATT 2 CHANEL 2 OHM AMPLIFIER WITH 4 4 OHM SPEAKERS, IA M USING THIS ON CONVERTABLE FOR PARADES AND NEED SOME SOUND.
  • 11,896 Answers
Posted on May 09, 2009
I need 4 ohm speakers for my Warrior IS600 Amplifier
It is rated as a dual 300 watt amplifier, shich strongly suggests a Class D peak value for each amplifier.
In theory- 100 watt RMS 4 ohm speakers should be adequate.
Sep 20, 2012 | Audio Players & Recorders
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
I have a Makita BMR100 radio. Stock speakers are 3.25" 8 ohm with an 8 watt 8 ohm amplifier. I replaced speakers with better 4" 4 ohm but they're not really compatible with an 8 ohm amp. I...
Buy an 8 ohm speaker and wire it in series-parallel look up images of of combination series-parallel wiring this allows wiring all speakers and keeping the 8 ohm loaf on the amplifier. Should get more linear volume between speakers. Not sure if replacement is worth it, those speakers are pretty good and work well with rain and jobsite conditions. I am planning to install some 8 ohm half inch tweeters on my Makita radio and using the series parallel wiring. Plead note series-parallel wiring is not series wiring or parallel wiring. It is s totally different way of wiring it that uses both names.
Jun 02, 2011 | Makita BMR100 Radio
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
Is the p3001 bridageable?
The Punch P3001 is a 2 ohm stable monoblock amplifier. It therefore has only 1 channel. Not bridgeable.
Below are the specs off the rockford site.
  • Punch P3001 - 300 watt mono amplifier
    150x1 @ 4 ohms, 300x1 @ 2 ohms, 12dB/oct HP/AP/LP crossover variable 40-400Hz, RCA inputs, RCA pass thrus, cast aluminum heatsink, military spec PCB, and remote Punch Bass EQ with 0-18dB @ 45Hz. H 2.4" x W 11" x L 11.7"
  • If you are using your amplifier at a 4 ohm impedance then you will only have 150 Watt delivered to your woofer or woofers. If you are running your amplifier at a 2 Ohm load you will be recieving 300 Watt to them. This however will also draw more current to deliver this power.
    If you are certain that you can deliver the correct current to the amplifier and you are running a 4 Ohm configuartion. Then consult a Rockford delaer for a sub upgrade.
    Aug 12, 2010 | Car Audio & Video
    How do i install 2 ckicker cvr to my amp
    Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
    Option 1 (parallel/parallel) = 1 ohm load
    Voice coils wired in parallel, speakers wired in parallel
    Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
    Option 2 (series/parallel) = 4 ohm load
    Voice coils wired in series, speakers wired in parallel
    Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
    Option 1 (parallel/parallel) = 0.5 ohm load
    Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
    Option 2 (series/parallel) = 2 ohm load
    Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
    Option 3 (series) = 8 ohm load
    All voice coils wired in series
    Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
    Apr 12, 2010 | Kicker CVR12 Car Subwoofer
    Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
    havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
    Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
    Why do the fuses in my amp keep blowing
    You may not have they proper size wire to the amplifier. Most amps now recommend 4 ga. Also make sure your wiring to the speakers are at the proper Ohm load.
    Dec 05, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
    Orion xtr15 to a american leagacy la 660 amp
    your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
    Positive on sub to Positive on amp.
    Negative on sub to Negative on amp.
    This is your only possibility.
    Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
    Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
    Mar 05, 2009 | Orion Xtreme XTR15 Car Speaker
    Wiring Diagram for Sony car amplifier XM-554ZR
    You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
    Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
    85 people viewed this question
     Grubhead
    Grubhead
