Question about Exercise & Fitness
MY HEALTHRIDER THREADMILL DOES NOT WORK AT ALL. THE ONLY BUTTON THAT WORK IS THE INCLINE UP KEY. IT DOES NOT START. THE PANEL IS KIND OF STUCK.
  • 1 more comment
  • patogonzalez May 19, 2009
    I AM GOING TO TRY ALL THOSE IDEAS. BUT I WOULD LIKE TO COMMENT THAT SOMETIMES I TRY TO USE IT AND IT STARTS TO WORK FINE FOR A WHILE, BUT AFTER A SHORT TIME THE PANEL GETS STUCK AND THE ONLY KEY THAT WORKS IS THE INCLINE UP BUTTON AND THE STOP BUTTON. I WILL LET YOU KNOW THE RESULTS.
    THANKS.
  • patogonzalez May 20, 2009
    I TRIED EVERYTHING AND DID NOT WORK. ANY MORE IDEAS?
  • patogonzalez May 25, 2009
    NOTHING HAS WORKED. ANY OTHER SUGGESTIONS? THE PANEL IS STILL NOT WORKING RIGHT. IT CAN NOT BE THE PANEL NOR THE MOTOR CONTROLLER, I ALREADY CHANGED BOTH FOR NEW ONES.
    THANKS.
    Scholar:
  • 93 Answers
Are you sure its the panel or is it the motor RPM sensor bad? When the senor becomes missaligned or broken the main drive motor will not operate. Some treadmills also have seperate fused for the panel and motor. Hope this helps.
Joe
Posted on May 26, 2009
    Sergeant:
  • 296 Answers
HI
Stand to the side of your treadmill and push your belt with your foot. Then start the treadmill. If you have worn motor brushes this can kinda jump start it and it may move the belt in a jerky manner. You would need to replace motor brushes and clean the commutator.
If on the other hand your treadmill doesn't start and stops when you quite pushing. Then your motor brushes are totally burnt or you lower control board may be out.
OR
You can try unplugging the treadmill and when you plug it back in the control board start-sequence might correct the issue. Or you can try recalibrating the walk speed according to the troubleshooting procedure in the image below, which might also reset the board. But most times the incline sticks in the up position on that model due to damaged wires going from the console down to the motor and control boards. There are actually two sets of wires that connect together inside the handlebar upright, a short one coming down from the console and a longer one coming up from the motor and control boards. They are the Console Cable and the Console Mast Cable in the Sears PartsDirect site images below. The two are likely still plugged together or you would have no functions at all, but the wiring can get pinched between the console and the uprights the wires run through. Or, they can be damaged by the end of one of the bolts or another connection point in the upright. Testing the wires for continuity with a meter is not always an accurate way to confirm this since you may not be able to determine partial breaks or shorts in the wiring and even partial damage can cause this issue. The only way to confirm the problem for certain is to remove the wires and give them a careful visual inspection. Be sure to make a note of where all the wires connect on each end to help with the reassembly. If it turns out the wiring is okay then you might have an issue with the incline motor itself, but that is much more rare.
hope this will solve your probs
regards
Posted on May 19, 2009
  • Anjana Batabyal
    Anjana Batabyal May 19, 2009
    hi..
    do let me kno:)
    all the best
    thankyou
  • Anjana Batabyal
    Anjana Batabyal May 20, 2009
    hi
    chek this sites,hope it will work out.
    http://www.associatedcontent.com/article...
    several things can cause the belt not to run or not run well,nd tht stops the treadmill to work ! so start with the easiest to fix items first like lubrication and tension adjustment (get a manual from the website if you don't have one--it covers this adjustment). Maybe clean the speed sensor wheel with compressed air.
    Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
    Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
    OR
    find someone who knows something about electronics, and have them check for a fuse on the treadmill (some have them, some don't). If there is one, check and replace it, if necessary (BTW, if you are using any kind of surge suppressor between the wall socket and the treadmill, disconnect it from the treadmill, then connect the treadmill directly to the wall socket; likewise, do not use any extension cords). If there is no fuse or if there's nothing wrong with the existing one, then disconnect it for at least an hour, then plug it in and wait. Press the "start" (or similar) button. If nothing happens, then the device might be shot. If it goes on and off, as you said, then you might have a short in the power cord, and should get it professionally replaced (warning: it could cost as much as $100 for a $5 do-it-yourself repair, but, for heaven's sake, don't do it unless you know what you're doing .
    hope this will sort your problem
    regards.
Threadmill does not always start
There would be some problem in wiring harness between motor control board and control panel. Try to remove form both side an reconnect it
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 10, 2016 | FreeMotion Xtr 90 Treadmill By Free Motion
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
I have different issues with threadmill
Sounds to me like the motor has a shorted field coil or open or shorted armature. The motor is bad, you can order a new one at the companies website.
Jun 09, 2014 | Nordic Track NordicTrack A2550 Treadmill
Healthrider 15.5 won't run,motor makes alittle grunt,turns alittle but won't run,incline motor works
hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Jan 10, 2014 | Exercise & Fitness
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
When starting my treadmill the incline just starts all by itself, all the way up, sounds like it would keep going if it could, then it declines, its stuck in this loop. the belt never starts and I cannot...
This sounds like the treadmill is running an incline calibration. It will run to fully inclined, then to minimum incline.
It should not do this every time you want to operate the machine, but they will do it automatically if the operation of the machine is stopped by the power being interrupted..
Jan 26, 2011 | HEALTHRIDER S600 Treadmill Motor Control...
Incline works all button works but the start button want start
If you have a unit where the start button is not working most of these units will make some sort of beeping sound if you depress start button and no sound it maybe the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Mar 01, 2010 | HEALTHRIDER Exercise & Fitness
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Exercise & Fitness Logo
181 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
