Question about MyGuide 3100 GPS Receiver
Wil not charge useing charger on U.S.B port icon bars[white] go up and down 2 amber stay were thet are if anything it,s taken charge from it been on charge for over 8 hours still not carged
  • 11,896 Answers
Sounds like it may need new internal battery pack. You might be able to get one from company website or wholesaler from the net.
Posted on May 09, 2009
I have put the charger in my laptop and the charger light is not coming on
Please check the voltage on the output of the adapter and if this is absent then the adapter is faulty. check the link below for tips:
http://www.fixya.com/support/r5164850-laptop_power_supply
However if there is voltage on the pins then check the voltage on the battery terminal pins in the laptop. If absent then the motherboard is faulty.
you need to use a multimeter to check and track the path of the voltage/current to confirm the area of fault in the charging section.
Aug 16, 2011 | Computers & Internet
My MacBook wont charge
So does the organge light still not come on now? If it doesn't try a different charger first. If that fails, your DC-Jack module or logic board may need to be replaced. There are detailed instructions on how to do the restore online. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jun 19, 2010 | Apple iBook Mac Notebook
Phone is in the charger and after charging for a little bit it stops charging and says "warning bad contact of charger" how do I fix this problem for nokia n97. Please help
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
Feb 25, 2010 | Nokia N97 Cell Phone
When charging the phone, the battery icon flashes off and on and the phone make a sound is it charging properly
hello,
it is not supposed to make any sound when charging, if it does it means there is a problem somewhere.
it is not charging properly. try to turn off the phone and plug the charger. its supposed to bring up a light the show the battery meter and show it charging bar by bar, if it doesn't come up this way, try using the same charger on another phone to see if the charger is working. anything you detect, try to replace the battery and try again.
Jan 27, 2010 | Motorola Mobility W377 Met Silver/Pink...
Got a new blackberry pearl will not charge is it
Try a different charger (like your car charger instead of your home charger) - make sure while it's plugged in - the display shows that the charger is charging it, blinking - or bars going up or down, or a thunderbolt on the display screen next to the battery power symbol etc
Once you know your charger is working, its probably easiest to find someone else with a BB and ask them if you can trade them batteries for a day to see if it's a bad battery. ( You can usually buy a battery for $5 on ebay, or up to $20 in a cell phone store)
All in all, trade someone for their battery, or their charger - if you dont wanna buy one at first. See if the problem follows your old battery etc..
And if neither solve your problem then its the BB itself. I have called in to the cell company before and let them know we have a BB that will not hold a charge no matter what battery or charger I use... and they usually replace it under warranty as long as its less than 12 months old, and the white squares in the battery compartment are still white.
Dec 31, 2009 | RIM BlackBerry Pearl 8100
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Audiovox smt5600 blinks amber light upon plugging in charger and wont charge and the (!)icon appears on the screen whichi n the manual means that the battery is either at too high or too low of operating...
Start with another battery. Borrow a friends or they are available on Ebay rather cheap. Or, go to your Cell Carrier and ask them to help you try another battery.
Have you tried charging it through the USB port of you computer? The phone is designed to charge from a USB port also, but computer must have ActiveSyn phone driver install and be recoginzed by the computer in order to charge using USB port.
Mar 01, 2007 | Audiovox SMT5600
MyGuide 3100 GPS Receiver Logo
137 people viewed this question
Top MyGuide GPS Experts
Ric Thomas
Level 1 Expert
LP
Are you a MyGuide GPS Expert? Answer questions, earn points and help others
