Question about Sony DVP-C650D Multi-disc DVD Player
Setup between tv and player - Sony DVP-C650D Multi-disc DVD Player
KS3102 no display. how to change back to NSTC from PAL
make sure there is no dvd in the dvd player before you start fixing the problem. Press menu on remote, then select setup. Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again
Apr 02, 2016 | Televison & Video
Codes for oneforall
It is my pleasure to guide you.
Look through these. I hope what you need is here.
Manufacturer's Codes
Setup Codes For Cable Boxes
Setup Codes For Cable Box/PVR (or DVR) Combos
Setup Codes For DVD Players
Setup Codes For DVD Player/VCR Combos
Setup Codes For PVRs (or DVRs)
Setup Codes For Satellite Receivers
Setup Codes For Satellite Receiver/PVR (or DVR) Combos
Setup Codes For TVs
Setup Codes For TV/DVD Player Combos
Setup Codes For TV/VCR Combos
Setup Codes For TV/VCR/DVD Player Combos
Setup Codes For VCRs
Please post back which one is yours with Serial number and Mfg.
Setup Codes for DVD Players such as Magnavox 0503, 0539, 0646, 0675, 0821,1268
Jun 05, 2011 | One For All URC4220 Remote Control
Hello. I have my HK connected to a new Sony TV. I see the video pic but hear no sound. I've made sure the TV speakers are on. Not sure what the problem is. Thanks
hi,
Check the connections you have made between the tv and dvd player, whether you have connected the audio output of the dvd player to your tv.
if its ok the go the system setup of you dvd player and then go to the Audio setup.
In the audio setup select digital output and make it to PCM.
exit menu and test
ok
Apr 11, 2011 | Harman Kardon DVD-22 DVD Player
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I accidently selected in the setup for TV type> Aspect 4:3 & 480p. The setting was on Aspect 4:3$ 480i. Now I cannot stop my screen from rolling so I cannot get back into the Setup area to change it back....
connect an rca connection cable on the yellow video output on your dvd player to your tv, grab your tv remote and select that input, then go to the setup menu on your dvd player and change the settings.
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Jensen Universal Remote
HOLA NECESITO SABER COMO SE PROGRAMA EL CONTROL REMOTO UNIVERSAL JER 422 Y SU CODIGOS PARA PROGRAMAR TV DEAWOOD, SONY Y SAMSUM
ATTE.
GERARDO
May 03, 2008 | Jensen JER-422 Universal Remote Control
Sony DVP-C650D Multi-disc DVD Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
