Question about HP f1905 19" Flat Panel LCD Monitor
Menu option My OSD Main Menu pops up and then the brightness and contrast sub menu appears. The menus will not go away. I could exit out of both menus, until I let go of a button to exit.
  • Anonymous Jun 02, 2008
    Exactly the same problem here. It doesn't appear to be the buttons..all they do is change the contrast menu to and from the strength bar
    Scholar:
  • 186 Answers
Stuck in adjusting button?
Posted on Apr 23, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
There is a blue lock that appears in the center of the screen
Change the OSD Lock option from ON to OFF by following these steps:
Press the Menu button on the remote or the control panel for 15 seconds to unlock the OSD menu.
When the OSD menu appears, select the Management option at the Main Menu, then select OFF at the OSD Lock option.
Select Exit to save the setting and exit the menu.
hope this helps
Aug 07, 2012 | Dell OptiPlex SX280 PC Desktop
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
How do I adjust the brightness on LG W2053tp
Look for the buttons, enter menu and the Brightness setting then use + or > to go up
Mar 07, 2011 | LG Flatron F700P 17" CRT Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Screen too bright, have just got monitor from e-bay and there are no instructions on use.
Check all the buttons near the ON/OFF button.
One of the buttons will activate the OSD (On Screen Display).
The OSD controls everything about the monitor, including BRIGHTNESS and CONTRAST. Use the other buttons to move between menu-items, and to "select" one of the sub-menus, and to raise/lower settings, and to "exit" from a sub-menu to the main-menu.
Nov 18, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP f1905 19" Flat Panel LCD Monitor Logo
331 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
