Question about Philips 32PT5441/37 32" TV
Philips model 27MS5402/17, chassis A02U AA - horizontal adjustments
Just replaced the tuner in this set due to a broken cable connector, and all is well with one main exception.  The horizontal size is a bit too large and set too far to the left (facing the set).  The problem causes vertical distortion waves in the first few inches from the left side.  Is there a way to correct the problem without specialized equipment?
Also noticed a quirk that I think may be due to its being inside a mobile home (metal).  When the set is facing south, a purple blob (looks like the tube needs degaussing) resides in the lower right corner of the screen.  As the set is tilted forward, the discoloration moves up the right side to the top right.  Go figure.
Any help on the horizontal adjustment will be appreciated.
May be the mamery is defective
Posted on Oct 11, 2007
Coax connector is broken off-how can i replace the connector?
You can pick up a chassis mount F connector here...you will need someone with basic soldering skills to replace:
http://www.electronix.com/rca-connector-p-13010.html
Oct 21, 2010 | Samsung TXG2548 TV
My son tripped over the cable cord and the cable/antenna input came off. Is it repairable and is it costly to get it fixed
It depends if the connector broke the tuner it is attached to. Most times the chassis of the set would need to go into the shop. I would generally charge $80.00-$120.00 if the tuner was still good - a new tuner would cost $60-$100 more if bad
The better solution is to use the video audio inputs (if on satellite or cable box) or use the video inputs by changing channels through the VCR (if on cable or antenna and a VCR is available)
Oct 22, 2009 | RCA P52926 52" Rear Projection Television
Tv turns on with remote but only for few secs..after 7=10 trys, maybe for an hour, then shuts off of cable.
The Horizontal Timing is getting worse. This is chassis L04.1U AA. Have a tv tech install the horizontal timing kit...Part# 4835 310 57673......You will be glad you did!
Sep 22, 2009 | Philips 32PT6441/37 32" TV
Broken connector
a new connector must be soldered in tuner if it was ripped out and did not break the pc board that it was attached to
if it was on a switcher u could replace the unit or solder in new connector
Sep 01, 2009 | Philips Televison & Video
Cable input connector broken off
Usually the connector or at least a new connector can be put back on. If there is minor damage to the board, a tech can repair it in most cases.
Jul 25, 2009 | Televison & Video
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
Feb 18, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Patgirl
The part is called and "F" connector. It can be purchased but it also muist be soldered in place. This is not a trivial task. The F connector is part of the tuner. For a set of this size, it may be easier to replace the tuner rather than fool around with a repair attempt. Depending upon how it was broken, the PC board inside the tuner may be broken as well requiring tuner replacement anyway.
Dan
Nov 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
1996 32 inch Panasonic TV
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Jun 27, 2007 | Panasonic CT-32G23 32" TV
Chassis blowup
Are you talking about your IF connector on tuner?you have to unsolder tuner then carefully open to reattach IF connector,if tuner is cracked then replace tuner.also you can go to www.repair world for more help.I seen where replacement broad wasnt alot to replace.
Jun 27, 2007 | RCA HD52W59 HDTV Projection Television
Philips 32PT5441/37 32" TV Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
