Question about HP Compaq Presario SR1503wm PC Desktop
The P.C. at startup says the fan needs to be replaced and then powers down.
Need to know the size of the blower fan so it can be replaced.
  • Jon Erik Haavie May 11, 2010
    I'm afraid you have to be more specific in describing what kind of PC you have. Manufacurer, model(number) and so forth.
  • Frank Zhang
    Frank Zhang May 11, 2010
    please tell me whats your destop brand model, and what the error say detail, cause there are different fan inside,.
  • 700 Answers
This warning could mean another thing. It could be overheating problem. For your question, just take off its cover then take the fan and measure its size then also get its spec. Its more direct and sure way.
Just power down your unit and disconnect from power source before doing that
Hope it helps.
Posted on May 09, 2009
I need to know the location of my blower relay. Already changed out the blower resistor, that did not remedy the problem (fan will not come on). Yes, I installed it correctly.
The blower relay is for high speed fan only most of the time . Do you know how to test electrical circuits ? It sure cuts down on buying unneeded parts . Here watch this video , this is a Chrysler vehicle . Don't know what you have , doesn't matter . They all work pretty much the same . I suggest you watch a few other trouble shooting videos as well .Is Chrysler Blower Motor Test subscriber requested video This next vehicle is a GM product , this one uses a relay for high blow only . Blower Motor Problems Auto Repair Help
Oct 30, 2015 | Cars & Trucks
How to check fan blower switch I need diagram of the switch
id find blower motor and hit it with a hammer if it turn on its bad also look at the wire to the resistor they melt down if its bad put new connector and resistor in iv done a few
Mar 04, 2015 | 2005 Chevrolet Silverado
How to change the under the hood fuse box on a 2002 pontiac sunfire
slow down. the relay for the fan might just be sticking or have poor contacts. Make sure you don't just have a relay problem before replacing the whole panel.
Mar 03, 2015 | 2002 Pontiac Sunfire
Blower motor grinding
The first thing you need to know is that replacing a furnace blower motor can be dangerous. You can be injured, you can loose your fingers, you can be electrocuted, you can be burned and you can be killed. Make sure the power to the furnace is off, just because it is not running, does not mean the power is off, just turning the thermostat down does not mean the power is off, Make sure the power is off at the circuit breaker, or the fuse is removed. I have found that 90 percent of the time...-----------------------------------------------------------------------------------------
Super VAG K+CAN V4.8
Jan 23, 2013 | GMC Cars & Trucks
I have a 2006 Tahoe with rear and front blowers and climate control. The front air stopped operating, but rear works fine. I replaced the blower motor resistor and air immediately started working again. ...
Hello: Remove the panel under the passenger side of the dash, look to front of truck, you will see the blower, follow the wires from the blower motor to the module, remove the connector and see if the terminals are burnt. If so GM has a repair harness to replace the burnt connector, if you need it make sure you have the connector positioned correctly so you get the wires in the proper order. In some cases the module may also be burned and if so it should also be replaced.
Jul 21, 2011 | 2006 Chevrolet Tahoe
The heater fan quit working on my 99 chevy suburban today. Any ideas on how to get it working.
KEY ON, FAN ON HIGH TAP FAN MOTOR NEAR WHERE POWER GOES IN, IF BLOWER RUNS REPLACE BLOWER MOTOR.
Jan 28, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Ac stopped blowing any type of air
things to check; blower fuse, blower relay, fan control, blower motor resistor, blower motor.
You can check for power at the plug for the blower motor and back track from there. If you have power at the plug then you need to replace the blower. A cheap 12V probe tester will tell you everything you need to know. Let me know your findings and we can narrow down the possibilities
Sep 03, 2010 | Chevrolet 1500 Cars & Trucks
High voltage
yes. you will need to know the engine size for the exact location. it is usually on the passenger side firewall.
Aug 09, 2009 | 1992 Jeep Cherokee Briarwood
How do I replace the heater blower fan in 1996 Dodge Dakota?
On full size Dodges, the blower sits in a housing under the hood.
ON DAKOTAS, I seem to remember the blower being located (fan upward) in the passenger floorboard. You will find one plug that needs unplugging, and 3-4 bolts around the outer edge of the black plastic that comprises the visible part of the fan ***'y. These retaining bolts are usually 7mm or 8mm heads, and require a 1/4 inch drive socket setup. SOmetimes one of these bolts is at a rear edge and is harder to remove than the others due to the rising floorboard and lack of clearance. Use a swivel or a hand-held nutdriver with socket attached for the tough one.
Once bolts are removed, the fan will come out the bottom of the HVAC housing. Watch for a mouse nest or other debris, and remove any foreign matter from the cavity where the fan lives. It's easier if you are a small guy who can crawl around in the floorboard! When you unplug the fan, check to see if power is getting to one of the contacts before condemning the fan motor. Good luck and let me know if you need any more pointers. Thanks for using Fixya.com!
Tater Todd
Jan 28, 2009 | 1999 Dodge Dakota
Heater is dead
My 2000 century heater blower died,dont replace the fan motor until you check with a simple test light to see if the heater fan resistor is bad first,it's only 20 bucks to replace.Its located next to the fan housing up against the firewall.The wires from the fan switch go down to the resistor, check to see if switch has power then check for power down at the resistor,I'll bet its the resistor.There are three, I think five sixteenth screws to remove the resistor one is crammed up very tight on the firewall,you'll need a quarter inch drive extension with a wobbly socket to get that one against the firewall.
Dec 13, 2008 | 2000 Buick Century
HP Compaq Presario SR1503wm PC Desktop Logo
57 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
