Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas
Pilot electrode does not spark so heater will not fire up.
Ignition lead does have power to the ceramic insulator assembly. If I replace this assembly will this ge t me a spark to the pilot burner?
  • 11,896 Answers
That is correct. You will need to replace the assembly.
Posted on May 09, 2009
My adp cuhn-60a-2 sparks an lights burner ok, burns for only few seconds an shuts down burner, repeats this three times an whole unit shuts down?
You are describing the typical issue for a problem in the 'flame rectification' circuit. Turn the powere off. Find the flame sensor, it will be on the opposite side of the furnace from the spark ignition device. Carefully remove the sensor and clean with fine sandpaper, then clean the wire connector on the end of it if so equipped, then follow that wire all the way to the circuit board, remove the wire connection and clean it and reinstall. Many times that solves the issue.
Some systems utilize the spark ignition electrode as its own flame sensor. IF there is no separate flame sensor, perform the above task on the ignition device instead. Be careful NOT to bend the probe, crack the ceramic insulator or reinstall it malaligned. Its location in the pilot flame is critical. Slight relocation by improper handling will render it unable to ignite the pilot gas.
There may be another issue as there are many things that cause ignition lockout, but this is the first thing to do to eliminate the situation you've described.
If you are unsure of performing this and ANY minor maintenance to a gas fired appliance, abandon the idea and call a qualified service tech to proceed.
Dec 29, 2014 | Heating & Cooling
Have 85000 but all-pro propane heater. starts fine good flame, release the gas valve button, heater shuts down no gas
If you have a thermocouple and standing pilot as described the gas cannot flow full to the burners with the gas valve button depressed because the position of the gas valve to allow the button to be depressed is not in the 'on' position....its in the 'pilot' position.
Are you sure you cleaned the 'thermocouple' and not just a 'spark ignition electrode' ?? One with spark ignition will not have a gas valve that has a pilot position.... Kinda confusing and conflicting data to sort through ..... Hmmmm....
If you have the spark ignition style, the problem COULD be in the 'flame rectification' circuit. IF it has the ignition electrode, the other side of the furnace will contain the 'flame sensor' that senses the flame and completes the ground circuit of the electronic module through the flame. Its not doing it, so either it is oxidized up inhibiting its ability to conduct electricity through the flame or there is residual oxidation within some of the terminal connections of the ground circuit.
IF what you have is the 'standing pilot', the first suggestion is to replace the thermocouple. A more remote possibility is the gas valve has a defective safety coil that drops out when you release the pilot button.
Dec 23, 2014 | All-Pro Heating & Cooling
Have master heater 200000 btu that has spark an fuel but will not fire can someone help me
If this is a fuel oil burner in a residential style forced air furnace, you probably have the electrode adjustment wrong. The generic measurements for the electrodes for an 80 degree hollow fuel flow atomized mist spray is 9/16" above the center of the nozzle, 1/8" gap, with a leading dimension of 1/8". Because the atomized mist leaves the nozzle at an 80 degree angle, electrodes protruding too far out will be drowned out by the fuel and not ignite. Electrodes not extending out far enough may cause a serious delayed ignition that will rock the structure, or not light at all because if the cad cell doesn't react to the UV rays of a flame, it locks out the ignition control.
When in doubt, its always back to basics first. If this is a torpedo style heater, it may or may not utilize the two electrodes for ignition as noted above and may just use a spark plug style ignition device, in which case the above dimensions are rendered useless.
Dec 06, 2014 | Heating & Cooling
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
THERE IS NOT IGNITION. IT SPARKES BUT WONT LIGHT.
sounds like your not getting gas...maybe a vapor lock,,,,,,,make sure you are compressing the pilot button all the way.....try to listen and see if you hear gas flowing....
Jan 19, 2013 | Bosch Worcester Spark Electrode...
Baxi Bermuda 5 bbu has just stopped firing up ,pilot light good
The unit is clogged up. Pull it apart and blow it out. If nothing is cracked or damaged it will fire right up
Oct 11, 2012 | Heating & Cooling
Spark plug settings honda jazz 1.4 2006
Inspect the electrodes and ceramic insulator.
  • Burned or worn electrodes may be caused by:
    • Advanced ignition timing
    • Loose spark plug
    • Plug heat range too hot
    • Insufficient cooling
  • Fouled plug may be caused by:
    • Retarded ignition timing
    • Oil in combustion chamber
    • Incorrect spark plug gap
    • Plug heat range too cold
    • Excessive idling/low speed running
    • Clogged air cleaner element
    • Deteriorated ignition coils
2.
Check the electrode gap (A). If the gap is over the standard, adjust the gap with suitable gapping tool.
Electrode Gap
Standard (New):
1.0-1.1 mm (0.039-0.043 in.)
3.
Replace the plug at the specified interval, or if the center electrode is rounded (A). Use only the spark plugs as listed.
Spark Plugs
NGK:
ZFR6K-11
DENSO:
KJ20DR-M11
Apr 09, 2012 | Honda Jazz Cars & Trucks
The fan works, no spark, have replaced ignitor assembly checked the high limit switch with ohm meter, room temperature switch is closed.
check for 24 volts at ignition module n pull the wire that provides the spark off the ignitor n see if it tries to arch or spark. your electrode on the pilot assembly might not be arching onto the hood of the pilot assembly. good luck!
Nov 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Propane Gas  Logo
170 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
