Question about Whirlpool Washing Machines
How to replace timer control on Whirlpool WTW5810SW0
My whirlpool - Ulitamte Care II, HD, Super Cap.Plus, 8 cycle, 5 wash/spin combo washer timer will not rotate to the drain cycle on all cycles. THe timer stops turning, and just before stopping it makes a load sound for a timer.
Posted on Dec 05, 2009
Need new cycle control knob for Whirlpool Model LLR8233BNO
You can order replacement parts online. Here is a site that I have used in the past.
http://www.appliancepartspros.com/top-cabinet-parts-for-whirlpool-llr8233bn0.html
There is a place to search within this model and if you type "knob" without the quotes, it will show you just the knobs for the washer.
Oct 18, 2013 | Whirlpool 3362624 Washer Control Timer...
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
We have a whirlpool duet front load dryer, why does it beep during a cycle?? when clothes are still wet?
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
May 21, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool dryer model LEQ8858JQ0 - won't turn off by its self, just runs and runs no matter what cycle it is on.
  1. Access the Timer
    Test the Timer
    Replacing the Timer
Apr 18, 2011 | Whirlpool LEQ8000JQ Electric Dryer
WTW5810SW0- Water level control is difficult to turn. It does work so I don't want to replace it. It appears on the back of the control unit there is an adjustment screw on the end of a push in button for...
It will break for sure if you keep attacking it like you are!
If it is stiff, just use some light oil to lube the shaft and rotate it back and forth with a pair of pliers until it becomes smooth of movement again. Then put it all back as it was.
SWITCH OFF THE POWER FIRST !
Oct 24, 2009 | Washing Machines
Dryer cycles
  • HI, this specific sector of the timer you speak of has been damaged. you will need to replaced the timer/control module in this case. the replacement of the timer/control module will fix this issue.
May 29, 2009 | Whirlpool Dryers
Im replacing the timer on a whirlpool washer . how does the knob come off?
Quick and easy... I'm guessing you've already got the control panel taken apart so you can see the back of the timer. Just take out the black piece that holds the timer and knob together and attach the new timer replacing the wire mount and black knob
Apr 08, 2009 | Whirlpool LSR5132PQ Top Load Washer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Washing Machines Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
