Question about Acer Aspire 5315 Notebook
Cant boot up says error recovery start up repair wont work how do i recover
If you are running Windows 2000 or XP, restart and watch for the black and white starting windows bar at the bottom Press either F% or F8 (it will tell you but be quick) to bring up other boot options.
Posted on May 09, 2009
Updated tool for restore Windows hard drive data
If the hard drive will not boot, use the Windows installation disc to repair the operating system. If that fails, install a fresh drive and install the operating system. Then attach the old drive to restore your data.
If you accidentally erased your hard drive data, you may need to purchase recovery software, or send it to a company to recover your files.
May 05, 2014 | Computers & Internet
Advent roma 1000 will not start up.
Hard disk drive has failed. Replace it.
Mar 03, 2017 | Advent Computers & Internet
Cant open quickbooks , message pops up error code 8000ffff
If your problem did not solve till now, i would suggest you third party tool which will repair your corrupt QuickBooks file and save your data in working condition.
http://www.recoverfilesdata.com/quickbooks-file-recovery.html
Free to Try Version is Available
Aug 10, 2012 | Intuit QuickBooks Pro 2008: Windows
Startup wont boot
Sounds like the best solution for you is to take it to a Repair Shop and have them reinstall Windows for you. If you had a legitimate copy of the windows operating system on it and there is a Certificate Of Authentication (COA) key sticker on the bottom of the laptop or inside the battery case, a honest repair shop will reinstall windows for $60 or less.
Apr 05, 2012 | Gateway MX6454 Notebook PC
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
Cant recover my system thru recovery disk.. how to start the recovery drive
I believe on Sony's you need to press F12 during boot up to access the Recovery Partition.
WARNING: This will erase everything on your Hard Drive
Mar 01, 2010 | Sony VAIO VGN-N130G/W Notebook
My 2 year old stepped on{or dropped } my Dell xps m140 and cracked the screen. I thought I would replace it myself..Before I do, I hooked up an external monitor to see if it still operates properly, well...
This error is also cause by the hard drive storage of your pc notebook, if you know how to locate the hard drive you just have to remove it for a while and then put it back, some loose connection of the hard drive cause the problem, if you find it still not working, you need to repair the system startup of Windown XP it is corrupted that's why it wont start.
Before attempting to check the physical parts of your notebook, try first to check and recover the Windows startup system.
In windows startup repair you can use the Windows Recovery Console.
Source: http://support.microsoft.com/kb/314058
Here's the step to start in Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
  4. When you are prompted, type the Administrator password.
  5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
  6. At any time, you can type Help for a list of available commands.
  7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
  8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
After you start the Windows Recovery Console, you receive the following message:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
1: C:\WINDOWS
Which Windows Installation would you like to log on to ?
(To cancel, press ENTER)
Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot be authenticated correctly. After you enter your password and the Windows Recovery Console starts, type Exit to restart the computer.
Use the fixboot command to repair the startup boot of your notebook.
Feb 01, 2010 | Dell Inspiron XPS M140 Notebook
When i start my laptop it wont start windows, it just goes straight to a windows error recovery screen, it says windows failed to start. a recent hardware or software change might be the cause. it...
I recently had the same problem. I also thought it was a windows update that caused this: forced shutdown, startup repair, etc. The last time it did startup repair it could not repair it. Lucky for me my pc still had one month of warranty left. So after leaving it with the "pro's" for a week, I called to say what's up, figured it out yet? The techs told me that they had run every diagnostic test available and all the hardware had passed safely. So I asked what it could be and they said, more than likely, that Windows Vista software had somehow become corrupted- the only repair to fix this? a complete recovery. They offered to do a recovery for me for $130- lose all info except what's on recovery partition.
(No, thanks, I'll do it myself.) Went online, found how to start recovery (Alt + Fn + F11, for my Gateway DX4710), did it myself, works fine now, haven't had a problem since.
On a side note, if your RECOVERY software becomes corrupted, you will need recovery disks to fix this. I got lucky this time, but bought a set of those (JIC) for 20$.
I now do a backup at least once a month so it won't be a TOTAL loss should it ever happen again.
As a worst case scenario, if you need to figure out how to recover your computer, looks like HP owns Compaq. You could start here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Hope this helps.
Dec 15, 2009 | Computers & Internet
Error # 0x0000c1F5 It wont start windows, or even recover with recovery disk. Just blue screen with this message says possibly hardware or software problem.
ok, step one:
get a bootable CD (acts like a running backup boot), and put it in. your computer should boot up ok (NOTE* if it gives you the option to start in safe mode, don't. that will prevent the next step. start windows normally).
step two:
once it is up and running, eject the boot CD and get your recovery CDs/DVDs. insert them and follow the instructions. with everything recovered, it should work fine.
step three (optional)
attempt to create a new set of recovery CDs/DVDs.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 5315 Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
