Question about Ruud Matching Split Air Conditioner
Thermostat inside home is completly blank and unit not working
The Thermostat inside home is blank and the unit outside is not working dont there is no icing everything is clean.
  • HANK MCNEIL May 11, 2010
    does your thermostat have batteries?
  • 121 Answers
If you dont have a lock on the service disconnect sometimes kids will pull the service shut off down. Or you can check the service disconnect Usually theres fuses in there that can blow. The breaker box can also be checked to see if it's tripped or not... try those solutions and I hope they will be helpful. Have a goood day! : )
Posted on May 09, 2009
My Goodman AC unit is not working when i turn on ac on with is cold but the fan not is not running why ? but the heat is working fine { fan is working with the heat
Generally the fan operates by the command from the thermostat. First thing I would try is put the fan/auto switch in the on position. If the fan comes on you have a problem with the thermostat or the green wire that goes to the G terminal on the thermostat sub base. I suspect he may not have programed the thermostat for the type of system you have or he doesn't have a jumper between the rc and rh terminal on the sub base. Sometimes the jumper is not required and the thermostat instructions must be read completely to get the answers. Goods luck hope this helps.
Oct 14, 2014 | Heating & Cooling
Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
Jun 19, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Dgaa056bdtb
The relay on the outside unit is stuck
May 25, 2013 | Coleman 3.5 Ton 13 SEER Complete Split...
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
I have a Honeywell RTH230 thermostat. Ive read the manual top to bottom and have set the temperature to 70 degrees and followed all the directions. But my home is still almost 85 degrees, and even hotter...
i am assuming the unit is coming on and all... there could be an issue with the refrigerant in the system such as a leak.. need to make sure the indoor fan is coming on and also that the outside unit is coming on..there are 2 copper lines at outside unit that are refrigerant lines the larger one should be cool and the small line should be warm.. there also should be hot air blowing out of the outside unit... if this is not happening you have a problem with either the freon has leaked or the compressor may not be coming on inside the outside unit \
Jul 20, 2011 | Honeywell Programmable Thermostat Heater
I walked across my carpet to reset the temperature on my Totaline P/N P474-1050 thermostat. When I touched the thermosat, there was an arc of electricity. The screen went blank and does not respond to any...
There are two options for this. You can try turing all the power off the the unit completely. The inside and outside unit and give it 30 seconds and turn it back on. This may reset it. Chances are you just burned it up. I hate this for you...
Hope it helps.
Jan 28, 2011 | Heating & Cooling
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Hello, We bought a Perry Home in Georgetown TX last March and it is still under its two year warranty. Our air conditioner stopped cooling today. It has been working well for over 1 year. We came home...
You have a 10 year warranty on your AC. Call a Goodman rep and have it serviced. It will probably be a bad compressor capacitor. Bad wire or no refrigerant.
Jun 26, 2009 | Goodman Heating & Cooling
My blower inside my house will not come on. outside unit either
Initially, it doesn't sound like your thermostat is working.
If it has a setting to allow the blower (air mover) to be operated alone or continuously, try that.
Generally, if the inside unit (air mover) won't power up, the outside unit will not turn on for more than a couple of minutes because if the inside unit isn't working, pressure builds up in the lines going to the outside unit and an over-pressure sensor will shut it down again.
Jan 09, 2009 | Friedrich QuietMaster Electronic SS12J30D...
Ruud Matching Split Air Conditioner Logo
95 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
