Question about Canon PowerShot A75 Digital Camera
Cannot insert Memory Card
When I try to insert new Memory Card, it will go in except for the last 1/4 inch.  It feels like there is an obstruction at the bottom of the slot. The little black button to the right is free-wheeling (not as it was before this problem occurred.
  • Anonymous Nov 13, 2007
    I have a similar problem. The memory card will not go in all the way. I don't think my black card-eject button has changed. I know the memory card is fine because it works in another camera. I have looked into the memory card slot and think that one of the pins is bent over.
  • 137 Answers
One of the connector pins have bend inside. (Mem card reader pins) You must open camera to correct otherwise you will struggle to get to it to correct problem.
Posted on Dec 24, 2007
SOURCE:
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Memory Upgrade Not Recognized
bad sign if the memory slot is damaged then there is probably with the motherboard then in saying that try getting 2gb of memory and insert it in to the original slot where you had the original 1 gb
Jun 18, 2012 | Dell Inspiron B130 Notebook
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
I don't know the memory card format code
try to format in phone first otherwise use a card reader where u can insert this card nd format it from pc....
Jun 13, 2009 | SanDisk 2GB microSD Memory Card
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Can not insert memory card
If this phone is new, there may be a dummy card that is in the slot for protection. remove the dummy card before you insert a real card. If the phone is not new and you have inserted one before, there may be an obstruction blocking the slot or, the cooper prongs are bent.
Mar 16, 2009 | Samsung SGH-t639 Cellular Phone
Softwares not viewable
did u try looking into applications manager in ur fone to confirm that whethter the softwares are there or not?if they r there n NOT INSTALLED then it would be mentioned "NOT INSTALLED" under the software name. if they're in the list and still not working then u might have to reinstall the softwares again as u did the first time in installing them. so i feel this wud definitley solve ur issue. other wise tell me again so dat i can look into the matter more closely and effectively. dont forget to rate me too [:)]
Oct 02, 2008 | Nokia N73 Cellular Phone
Samsung D600 memory card format
When i insert memory card it says not allowed
Mar 03, 2008 | Samsung SGH-D600 Cellular Phone
Memory card stuck in camera slot
No need for pliers! I was able to eject the memory card by sliding a packing knife along the edge of the memory card. The blade was very thin, narrow, and long. I'm not sure if a regular box cutting knife blade would do. I've been able to eject the memory card with ease about a dozen times using this method.
Since I can't eject the SD card on the go, I use the USB cable to download images from the camera. Glad to know I can remove this when absolutely necessary, but sure wish I could remove anytime I'd like.
Jason
Jan 24, 2008 | Samsung Digimax 4010 Digital Camera
Canon PowerShot A75 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
