Question about E-Machines T6524 PC Desktop
I ahve an emachine T6524 and when you start it up the hard drive light comes on yellow and the cpu keeps beeping. It never seems to boot up. Nothing appears on the screen
  • dthomas269 May 09, 2009
    Thank you for the advice. When you say clean the memory are you saying to the chips out and clean the contacts?
    Thank you for your help. It worked!! I pulled out both of the memory chips, Cleaned and then replaced one of them in the opposite slot from where is had been. The cpu booted up and when I looked at the properties of the memory which is a 512 mb, it is only giving me 384 so it may be not completely working. I plan to swap it and put the other one in and see what it is giving me. This was really helpful as the last backup was not very current so now that I have that taken care of, I can do a little more checking into the other chip. Not to say what you saved me in the pocket. Thank you so much.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
Posted on May 09, 2009
  • Nelson Olaso
    Nelson Olaso May 09, 2009
    hi..yep...yes try to remove the memory and then clean easily the pin connectors of memory..wait..use only the paper eraser..thanks
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
The desktop will not boot. When powered on, the fans start, and the optical drive cycles repeatedly. Nothing on display - light on display stays yellow. I have tried unplugging rhe CD drive. No dice. I...
Bios is checking to see if the components are recognised.. usually keyboard is "seen" first. I have to concurr with you that given the things you mention, the mobo is indeed toast, especially as there are no beeps on boot up that would indicate a specific error
Jan 03, 2011 | AOpen (S661GXM-U) Motherboard
Have an e machine t6524 that was rebooting itself now it won't boot up at all. Keeps beeping
Hardware fault. Simple test: if you can boot in the BIOS then the hard disk has died - replace it and reinstall. If you can't the the motherboard has failed - in the end it will be easier and cheaper just to get a new pc.
Oct 11, 2010 | eMachines T6524 PC Desktop
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
MY T6524, will not start I press the button and the hard drive light goes red then nothing comes on the monitor
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Nov 19, 2009 | E-Machines T6524 PC Desktop
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines T6524 PC Desktop Logo
372 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
