I have a Denon AVR-285/985, about 5 years old. Has worked fine in all modes. Today, out of the blue, it stopped transmitting video to the tv/monitor. A light has appeard in the display that says "voff" but there is no reference to this in the manual and we can not figure how to return video feed to the output. Many tests have narrowed it to this problem (i.e. TV works of antenna; audio from all sources still goes through; etc.)
  • dab9874 May 09, 2009
    Solution turned out to be simpler than that -- universal remote was in the wrong mode and got sat on. After much trial and error discovered that the volume control in AUX mode turned the video back on. Thanks anyway.
  • 163 Answers
It sounds like its in the wrong display mode. Hope this helps.
Posted on May 10, 2009
    Novelist:
  • 130 Answers
In the unit there is video processor and audio processor.in your unit the audio processor is perfect.but the video processor is got bit weak.so its not supporting all the functions to get video and supporting some. you will have to get the video processor replaced.you can get the parts from service center.its like a square chip.of about 4 by 4 inch. that needs replacement.
please do rate the solution.thanks in advance.keep updated. thanks
Posted on May 09, 2009
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
I have a denon avr-2807 receiver. on tv mode, i can only get analog signals. i am using an optical cable and the signal is only transmitted in digital. how can i correct this?
An optical cable is digital but its only audio not video. Are you connected to a cable or satellite box, are you using composit video, s-vid, component video, or hdmi? What kind of cable goes from your denon to your tv?
Aug 19, 2009 | Denon AVR-2807 Receiver
NO GUI displayed
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
May 30, 2009 | Denon AVR 3808Ci Receiver
Denon AVR-1705 Missing Video Functions?
What you need to do is connect all your devices to the Denon Using the best connections (Yellow Video=OK, S-Video=good, Component green-red-blue=better and HDMI=best. if you do not have a DVD that upconverts to 1080i or p when using HDMI, I would use component cables where available from your devices to the Denon other wise use the next best connection available and if connecting digital audio make a chart of all connection so you can setup everything when your ready for programming the Denon
Feb 11, 2009 | Denon AVR-1705 Receiver
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
