Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
Pump will not start and it just hums. When I
Pump will not start and it just hums. When I first turned the pump on it hummed and then sparked fire. I replaced the capacitor and that did not fix the problem.
  • 59 Answers
If it has been sitting since last year, some rust could have kept the shaft from turning. Get some pump pliers and try to rock the shaft. after you get it freed up, turn it back on.
David
Posted on May 25, 2009
1993 hyundai excel won't start
Hi there sound very much like a failed fuel pump, they are electric and is possibly under your back seat, turn ignition on a listen closely for a humming noise, if not there then I would say you need to replaces the pump, check to see if you have power to the pump first, use a test light, hope this helps cheers good luck
Mar 08, 2014 | Hyundai Motor 1993 Excel
Turns over but wont start
try this , turn key on without trying to start and listen for humming sound coming from tank. would be better to have someone listen around gas tank while you turn key. if no noise or humming this may indicate that fuel pump is bad.....check fuses first...if you find that this isent the case then check the fireing system,eastest way is check to see if spark plugs are getting fire......after checking this fill free to contact me for more info.....good luck..
Aug 16, 2012 | Mitsubishi Diamante Cars & Trucks
20 Gmc Yukon .wil not start replaced fe pump 1yer ago .. The enine spuns strng bt it want kck over and start
check wiring connections[fuel pump] and fuel filter --quick and easy way to check pump turn key and listen for hum of pump if hum pump running /under hood check fuel pressure at fuel line test valve [shrader]or spray starter fluid if fires up u have fuel problem if not can be many reasons from egr valve ,cat conv-pcv-these are usually the ones that dont set off a code
Jul 07, 2011 | 2001 GMC Yukon XL
I got a 93 ford areostar. i just replaced the front caliper and rotor. i started it up went to push the gas and it dies. empty tank. i went o put gas in the tank and it has spark and fuel delivery but it...
  1. sound like a bad vacume leak start there first if not fuel pump check put your head bye the back tire and have some on turn the key to the on pos listen for humming sound if no humming a bad pump
sec check for spark pull a spark plug wire off and with a screw driver against the metal turn the key and look for spark try that
Jan 27, 2011 | 1993 Ford Aerostar Extended
It turns over but will not start people have looked at it have thought altenator, or battery, or fuel pump...just don;t know
not alternator or battery, maybe fuel pump. You will need to troubleshoot--are you willing?
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 07, 2010 | 1997 Chevrolet S-10 Pickup
My pickup shut off at the red light and only sputters when i try to start it. could it be fuel filter or fuel pump
try listening when you turn key on for humming from the fuel pump. hear humming, pump working. no good test for filter except replace w/new one check for spark from coilpack.rule out this question,, spark? or no fuel? that will narrow the search for cause of no start. hope this helps!!
Aug 16, 2010 | 2003 GMC Sierra
1996 chevy monte carlo problems
try start with starter fluid if starts than need to check fuel filter and pump again turn key and have u or someone listen at tank for hum of pump if hum turn off and open cap to release pressure check fuel filter and or replace if needed turn on pump and check pressure at straider valve on fuel rail by fire wall drivers side if pressure vehicle should start / if no hum at pump check connections to pump and test pump new doesnt mean free from defects repair or replace as necessary
Jul 23, 2010 | 1996 Chevrolet Monte Carlo
My Safari will turn over but not fire? Why
When you turn the key to the on position, listen to see if you can hear the fuel pump running in the gas tank. You should hear a humming noise coming from under the van. If you do not hear the humming, check the fuses. If okay, use a can of starting fluid and someone to start the van(a two person process), spray the starting fluid into the air intake; keep spraying while the other person is starting the van. Do this for approximately 60 seconds. If the van starts up you have a fuel delivery problem; especially if you hear the humming noise coming from the fuel tank. The humming at least lets you know that you have power going to the fuel pump. The fuel pumps go out on these vans every now and then. If you live in a hot climate don't let your tank get below 1/4 of a tank; if you do this, it will lengthen the life of the fuel pump. More fuel in the tank allows the pump to run cooler. Check the fuel filter. When was the last time that it was changed? If the pump is indeed bad you will be changing the fuel filter, the pickup sock, and the fuel pump. Make sure you have not run out of gas.
Feb 09, 2010 | 2001 GMC Safari
02 grand am died while driving,thought it ran out of gas, put gas in wont start still.have no fuel pressure but security light isnt on.
First off, you should turn the key on and see if you can hear the pump hum for about three seconds. You may have to take the cap off and have an assistant listen for the hum. If there is no hum, locate the relay. It is under the hood in the fuse block. The bottom of the cover should tell the location of it. Most of the relays are the same so swap out an identical one. Try the key again. DON'T TRY TO START. Just see if there is a hum in the on position. If there is no hum, try striking the center of the gas tank with a rubber mallet. One solid blow is enough. Listen again for the hum. It may start, but your pump is definitely bad. It may not start again. To change the pump, siphon the tank as low as possible. Disconnect the wiring, the filler tube and the two straps holding the tank under the car. A new pump will have the rest of the instructions for the job. Good Luck. If the pump does hum, you don't have a problem there. Check for spark. If you have the quad4 engine, check the coil pack cover for wear. It's like an inverted distributor cap mounted to the bottom of the cover, it is white plastic and can break down with age and mileage. If you have another car, have the coil packs tested. Oh and if you do hear the fuel pump turn on, try replacing the fuel filter before dropping the tank to change the fuel pump. Good luck.
Nov 03, 2009 | 2002 Pontiac Grand Am
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
1,159 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
