I tried several different cards but no luck. Cards work ok on other computers.
No video on k7vkp2 computer motherboard. I need dip switch positions. I also want to verify hook-up to J25.
    Novelist:
  • 152 Answers
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
Posted on May 30, 2009
I have a PI865D7 mercury motherboard when i start the pc, computer turn on fan is running all light on but no display in moniter i check the ram, it is ok so please could you help
you may re-seat your ram, video card and processor and pci cards. Turn it back on and see if that works. If you have to do that often then your motherboard has a bad connector or socket on it. If you just installed somthing on your pci slots take them out. If re-seating your ram video card processor and pci slots doesn't work, remove all pci cards and try, If that method works, install them 1 at a time and see when it stops working to isolate the problem.
Good luck hope your motherboard isn't shot,
Christopher
May 27, 2012 | Mercury Computers & Internet
When i on my desktop it show blue screen and says no signal analog
That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
(who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
Oct 02, 2011 | Computers & Internet
No sound
Hello
Make sure the audio jumpers on the motherboard is in the correct position.If possible,refer to the manual of the motherboard to verify the settings
)Are the speakers you using is working and powered on.Check out in another computer,if possible
Try to remove all expansion cards example modem,DVB-cards etc.Just install the video card thats all and then check the sytem.
Have you connected to the right ports of the computer.
Is the audio device built-in on the motherboard or is it a PCI card?
Try to remove all drivers from the device manager and extra software you might have installed and reboot.See if windows detects it or not.
Motherboard could be faulty or the PCI card whichever you have
If it is a PCI card,remove and reinstall.If possible try using different set of speakers
Remove the PCI card,if it is one,Try to reinstall windows,if possible and don't try installing the drivers at the start of the computer.Soon after windows finish installing,Shutdown the PC,insert the card and then boot system.See if windows recongnizes it or not.
Jan 22, 2011 | Intel D845GVSR Motherboard
Monitor does not turn on. HP Pavilion f1903 Switch light just continues to blink
Reseat the connection of your video card from the motherboard.
If problem still continue, try using different video card on your motherboard and see if it works. If the display is OK then you will be needing to replace your video card permanently.
May 26, 2010 | HP Pavilion F1703 17" LCD Monitor
There is no display. my ram, CPU and all other parts are in good condition. the keyboard light is on and the cpu fan starts automically.
If your monitor is working properly, the you might have a bad video card in your computer. Try several isolation.
1. Try to plug another monitor to your computer.
2. If you have a built in video card, try to install an external video card to one of those pci slots on *********** board.
3. If you have an external video card, try removing it from its existing slot and place it in another slot.
Nov 01, 2009 | Intel 845GEBV2 Motherboard
Intel d845,one long 2 short beeps video problems
hi im josh in cebu phils.may i help you? friend try to use this solutions of mine surely it will help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician. Just try friend it will help you Good luck.
Mar 05, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
My computer
install a new graphics card onto the motherboard into one of the free slots. i prefer radeon cards for durability. if you need more detailed instructions on how to do this please post back! good luck.
Sep 19, 2008 | Computers & Internet
Video
Sorry to say, but I just can't understand youre grammar. Maybe you need to put some marks on your sentences such as comma to specify thought.
Anyway, based from my understanding to your problem, your computer tries to boots but you cannot see anything on the screen(I hope this is what you really mean)..
And you have already tried switching video cards, so maybe you have plenty of video cards there. Hmmm.. so if you have already make the swithching technique, that should have solved the video problem, unless all your video cards is not working.
Why dont you try to connect your video plug to the onboard graphics(this is the motherboard plug for your video device). If its still not working there, then there must have been a problem on your motherboard, since you have told that it boots up and has a beeping sound. Maybe the onboard graphics is already not workiing.
Dec 16, 2007 | Intel Desktop Board D815EEA2 Motherboard
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
