Question about Flat Panel Televisions
Kolin DLT-3212M display not showing all channels
I have this unit connected to my cable and it shows some of the channels but not all of them. I have done an Auto Search, but it still does not show all of the channels. Can you help me?
  • 291 Answers
SOURCE: auto channel search.
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Posted on Nov 30, 2008
  • 291 Answers
SOURCE: can't get the channels to enter into the channel list
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
SOURCE: Suddenly the Tuner mode reports "No Signal"
Just a solution.
I attached a video recorder., and selected the video channel.
I was able then to see the channels through another AV slot extension.
Then I reset the TV to factory settings.
Samsung full HD reset code is 0000.
I used the original remote control.
I pressed the button TV/DTV to switch between mode., and from the menu I started
the option to scan the channels automatically.
Because the VCR was still connected it looks like it was forced to admit the channels.
I turned off the VCR and click on the TV the remote control for a known channel ( alternative control used) and surprise ... The TV started to react according to expected.
I disconnected then physically the cabling from the VCR and plugged in directly on back on the
wall connector. All is ok.
What was the reason ?
My wife dropped the alternative remote control ( not the original one) on the floor, and apparently an strange code was sent to the TV., which suddenly displayed " No signal".
I hope this can work for you.
Kind regards
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: After I reset my Olevia 542-B11 with
unplug televison for about 1 minute.
Go into menu picture>mode> powerup> and switch to home mode
Posted on Sep 05, 2009
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
SOURCE: I get no sound or
I'm having sound problems with Gem too, as are others, apparently. If you are getting program info but no picture for either of these, however, I suspect that you may only have a SD digital receiver, rather than a HD (High Definition) one. Can you receive the One HD sports channel? If not, that will be it for sure.
Posted on Oct 11, 2010
0 characters
1 Points
Video will not display on chanel one screen dark but red record button showing on
If you're connecting to the TV with a unit that you believe is supposed to be transmitting on channel one, check other channels and also check for a switch to select what channel it's transmitting on
Feb 02, 2015 | Flat Panel Televisions
Sharp tv won't display cable picture (it only shows fuzz) but the netflix and DVD both work. The cable says no input service available. I am able to change the channel on the cable box, but on the tv
Your cable box might not be sending signal out to the tv. Would have to call service provider to have them test your box. Or, you can try unplugging your cable box, and then plugging it back in. Make sure all connections are secure and settings on your tv are accurate. 11_13_2013_3_31_52_pm.png
Aug 11, 2013 | Flat Panel Televisions
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Flat Panel Televisions
I have an e470vl vizio hdtv. i was plugging another component into the wall when the whole outlet sparked (biggest i have ever seen/felt). the tv and dvd player were connected to a power strip to that...
first of all just switch off everything then switch off the mains, open the mains socket as there might have been a loose connection to the terminals which you`ve got to tighten. also confifrm that the earthing is well connected before you switch on .
swtch on the mains then switch on your devices one by one, also confirm that the VGA cable is well connected to the display unit
Sep 17, 2011 | Flat Panel Televisions
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Nov 02, 2008 | Sharp LC-32SB24U 32 in. LCD TV
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Flat Panel Televisions Logo
50 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
