Question about GE Refrigerators
Ge side by side frig lights not working on one side.
I changed the bulbs. Still not working.
  • jholloway1 May 09, 2009
    Thanks. Appears that was it.
  • 1,000 Answers
Good morning Jholloway1,
If you have changed the bulb and it still does not work, you will need a new door light switch. I'm not sure what type of switch you have, I would need the model number for that, but most "plunger" style switches just pop out, you unhook the wires, reconnect the wires to the new switch and snap the switch back into the refrigerator chassis.
Good luck, this should fix it. Let me know if you have further question.
Regards,
Posted on May 09, 2009
Frig LED settings and bulb do not work
u might have unpluged something
Feb 13, 2010 | Refrigerators
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
GE side by side frig: JSS22JEMC WW
sounds like defrost or fan problem let me know and I can help you
Apr 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
