Question about Traulsen Commercial 2 Door Cooler / Refrigerator
Hot electrical smell from back lower fridger and trips breaker
Keeps tripping breaker
Unplug it and call an electrician QUICKLY!!
Posted on May 09, 2009
Keeps tripping breaker when put into start mode.
Hi, if you have burnt electrical smell and the breaker keeps tripping you have a short in the motor that's what causes the tripping in the breaker. You will have to get it repaired or claim if it's still under warranty.
Mar 20, 2016 | Bowflex TreadClimber TC5000
My tub keeps tripping the breaker, but after it kools down I can trip the breaker back on, but it hits 100 and trips the breaker again, could this be the heater?
What Trips?
  • the "Actual" electrical circuit breaker?
    • Is it GFCI Style?
or...
  • Is the high limit switch tripping?,
    • which isn't actually a breaker.
  • A circuit breaker is a breaker that toggles as a switch, and to reset it you have to switch the toggle switch ALL the way to Off position to reset, then switch it to on.
    • Same thing if it were a GFCI style, it just has a 'Test' button on the body of the breaker, that button is usually a white rectangular button.
  • Some systems have a GFCI breaker that looks totally differnent from above... It's located on the control system itself, very similar to what you may have in your bathroom or kitchen of your home! It will have a 'Test' button AND a 'Reset' button.
A High Limit Switch, acts like a breaker, as it will trip when it senses a temperature greater that it is set for as a safe temperature. Once that temp is breached, it will trip.
So... Which one is tripping for you? What are you resetting to turn it back on?
if circuit breaker, it has nothing to do with the 100 degree temp you mentioned. If that trips,= electrical problem, either a short or overheated electrical appliance (internal wires) aging motor pulling too much current, loose electrical connections generate heat, etc.
if High Limit, then possible overheat of water? Many times, failed thermostat. I already know what you're thinking... But I never saw water get Hot! But... Many times that IS just the case , it's just you never noticed the water hot, and it has been cooling down when you saw it.
Apr 14, 2015 | Pool & Spa
Truma hot water system keeps flicking the circit breaker please help
If this has worked in the past check all the electrical connections and be sure they are tight. You might consider changing the breaker as excess trips tends to lower the trip point. Check the heating elements and be sure they are isolated from ground if not replace them.
Nov 29, 2014 | Water Water Heaters
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Why is the reset on my electric hot water heater keeps tripping
Have you tried another breaker? Check the ground wire and natural. And make sure no water around any wires.
Jul 18, 2014 | Whirlpool Water Heaters
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Bad upper element. Test upper element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The compressor gets hot and trips the breaker
More than likely what happen was the internal overload in the compressor was tripped and didnt reset for 5 hrs and when it did it popped the breaker. The compressor was probably already shot. Sorry
Apr 29, 2009 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
