Question about Mtd Garden
It won't start
Replaced switch and solenoid.Does nothing when turning switch.Tried jumping from solenoid.Will turn over but not firing.
  • 1 more comment
  • naylor288 May 09, 2009
    The deadman switch is disconnected so its not that.How do I know if the clutch switch is working or not.
    How do I check the clutch sitch?The deadman switch is disconnected so its not that.
    wHERE IS THE COIL PICKUP?i TRIED LOOKING UP ON MTD PARTS LIST FOR MY MODEL BUT COULDN'T FIND.
  • 11,896 Answers
Ok. since you replace switch and solenoid. The problem is either the coil which is the little box that the cables connect to. You can use an ohmmeter or voltmeter to test. I also recommend doing same with clutch switch. Place one probe on one prong, and other probe on other prong. If you get a reading, than it is good, if not it is bad.
If you can jump wires directly to solenoid and it turns over, the problem is most likely the coil.
Posted on May 10, 2009
  • Nate Stansfield
    Nate Stansfield May 10, 2009
    The battery can be checked at an Auto Supply like O'Reilly's for free.
    Also there should be a 15 amp fuse called an in-line fuse (Buss ATC) that
    goes in the line from the switch to the solenoid. It to may be bad and can be checked with digital ohmmeter
    Sergeant:
    Champion:
  • 219 Answers
check deadman switches on seat and clutch/parking brake pedal also make sure deck is up and blades are disingaged
Thanks!
Sandy
Posted on May 09, 2009
  • Sandeep Gupta May 09, 2009
    If the motor rolls over but will not start, check the oil. If that's
    full, then there's one of two problems. Either the coil pickup is bad
    or the electrical piece under the flywheel is bad. This looks like a
    long curved plastic thing with copper wire around it. If its the older
    style with points, clean them with an emery board or replace them. If
    you need to do this, they need to be reset. place a matchbook between
    them in the closed position and tighten the bolt.
    Thanks!
    Sandy
    so in that case u need to check the coment i have provided.i.e my second solution.It will fix ur problem
Battery hot wire hot at solenoid but no fire at start switch.Can jump solenoid and it will turn over. What do I look for?
The start switch ? Do you mean the starter relay your jumping the solenoid on the starter and it starts right but when your in the vehicle and you turn the key you get nothing right if this is correct the starter relay is no good when you turn your key in the steering column lock that moves the ignition switch on the steering column sending voltage to the relay then the relay sends it to the solenoid which then powers up the stater motor then it cranks the engine//// so the relay is bad
Mar 31, 2015 | Cars & Trucks
I have a husqvarna 42'' cut lawn mower. I can't
Test the small lead on solenoid for volts when you turn the key. The small lead is what jumps the two switch leads together internally with key in start position.You should be getting 12 volts or so on this small lead, if you have nothing there, check the key switch. Sounds like the key switch isn't sending power to solenoid. Also, check all grounds. Good luck
Sep 05, 2013 | Garden
Turned off car now it won't start I changed battery and still nothing
is it turning over at all ?? or just not firing ,if not turning over it could be immobilisor so try spare key first
Jun 15, 2012 | 1997 Toyota Camry
White lt-13 cruisematic won't start
use jumper cables direct to the starter that will test the starter next jump power to the small wire on the solenoid that will test the solenoid next jumper the safety switches with a paper clip
May 20, 2012 | Garden
John deere Z225 riding mower won't start .hour meter lights up .jumped across starter solenoid and it started three times and run.replaced with a new starter solenoid and nothing then tried jumping...
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Sep 12, 2011 | Garden
Craftsman lt1750 with kohler cv491 engine. I have a new battery,checked the seat switch,made sure the brake was on and pto not engaged but I get nothing. Any ideas?
start solenoid def will it start if you jump it off by placeing the red possitive to the starter cable lug. the solenoid is about 15 dollars.
Aug 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
96 ford explorer wont start. all power when turn key. nothing.
if it turns over from below,then its in the ignition switch and this also feeds power to the e.c.m. to make the engine fire so you either have a bad switch contact or the hot 12 volt wire to the ignition switch
Mar 20, 2010 | 1996 Ford Explorer
Kawasaki zzr400 (1994 model),streetfighter wont start
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
1995 Winstar will not turn over
try changing the solenoid it sould either be on the fire wall or on the starter itself
Jan 19, 2009 | 1995 Ford Windstar
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
