Question about Brother HL-2040 Laser Printer
Making grinding noise
When you put in the new cartidge it's making a grinding nosie and will not print.
My email is
  • 121 Answers
Re: Making grinding noise - Brother HL-2040 Laser Printer Printers & Copiers
You have a bad cartridge.
Posted on Oct 27, 2007
0 characters
3 Points
Why is my printer making a funny noise when I hit the print button?
that sound come while printing that sound is formed while cartridge or ink
if you want to clear that sound you should keep some oil to move free edges or you can clean
Feb 09, 2015 | Printers & Copiers
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
HP C310A grinding noise
Grinding noise is unusual. Check for the following ...
> Place the printer on an even surface.
> You may remove the ink cartridges and install them back.
If issue still persists, please call HP Tech Support as the printer requires a service.
If you are from USA and the printer is Out of warranty, then you may be provided an option to Trade in.
If issue still persists, please call HP Tech Support for further assistance.
If you are in US , the toll free # is 1-800-474-6836 .
If you are not in US , then log on to , at bottom-left corner there is a world map icon, click on it and then select the region you belong to, which would then provide support options for you for that region.
Apr 01, 2013 | HEWLETT-PACKARD C310a All-In-One InkJet...
I have an epson stylus cx6000, after I put in a new ink cartiage it started making a loud grinding noise an now it won't print.
Sounds like a cartridge jam. Remove the cartridges and look at the carriage path. Make sure there is no paper or anything else in the way.
Sep 10, 2010 | Printers & Copiers
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
Mar 31, 2009 | Dell 1720dn Laser Printer
Hp Laserjet printer okay, but making noise
Please rating my solution :-)
If i helped you.
Mar 19, 2009 | HP LaserJet 5000n Printer
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
185 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
