Question about Jeep 55117-JQ Stroller
I have a jeep buggy and i need to find the screws/bolts that hold the pushing handles together as mine have fallen out, i was wondering if there was an shop or place i could get some from?
  • 127 Answers
Any hardware store carires these you just have to know the right size.
Posted on May 11, 2009
97 mercury cougar xr7 how do i get door panel off if I cant open door?
It should still be possible, using a little bit of force. all screws and bolts holding on the panel are accessible, even with the door closed...but the panel maybe slightly pinched on the front and rear ends, and possibly on the bottom...but pulling hard on the handle once every bolt and screw is removed should force the panel loose
Apr 18, 2014 | 1997 Mercury Cougar XR7
Assembly manual
To remove the crank (the arm the pedal is attached to), you'll need a special tool. I got mine at a bike shop. (Bike shops are our friends.) I use the Park Tools CWP-7. It's pretty much a big bolt with a smaller bolt going through it. You'll remove the cap covering the spindle bolt (if it hasn't fallen out already), remove the bolt that holds the crank are onto the spindle, then thread the "big bolt" part of the tool into the threads for the cap on the crank. You'll then screw the inside bolt into the big bolt, which will push the crank arm off of the spindle.
Dec 30, 2013 | Genesis Onyx 29" Cruiser Bicycle
1999 Volkswagen passat window doesn't work has power to it and td
THis is common Too common. As I posted before.
As I posted in the Passat questions.
The jetta may slightly differ.
Yes. If your window has fallen down and will not roll up.
99% Chance you car is suffering the Infamous VW plastic clip.
The door panel comes off With a T-10 torx or a Hex (Allen) wrench
that will fit and A large Philips Screw Driver..
Remove the Plastic cover on the inside Door handle.
And the Screw or Screw along the Bottom of the door panel.
Then remove the screws that hold the handle the the door.
They are located behind the Plastic plate you removed with a tiny screw driver earlier... Be careful not the mark up the cover whaytprying it up. It is best to pry from underneath. Where marks if made can not be seen
After the screws are out 4 I believe. The Use of a CLip tool ir best.
For getting behind the panel to pop it off. A screw driver will work.
After all the clips are released. Pull the light at the bottom of the panel down and out. Disconnect it ur push it back thought the hole it came from..
Now you need a 10mm socket, or wrench to remove the 12 bolts that hold the metal plate to the Door. Remove all the 10mm bolts, If the widow has not already fallen in the door. It should be released. By removing the Black 2" plugs. THe loosen the bolts that clamp the window the the arms. DO NOT LOOSEN THEM ALL the way, .
Disconect the all the wiring.. THe Door lock cable,can be a pain.
I think it pulls down,.
Next remove the Metal plate. that is the regulator.
reverse to install
SKETCHLAB.com
May 22, 2009 | 1999 Volkswagen Passat
A screw is missing from my maclaren buggy
hi,
I had this problem and just went to my local diy shop and they sold me a nut, bolt and washer. You just need to make sure it'll fit in the hole. Cost me 15p!
May 22, 2009 | Maclaren Quest sport - Placid Blue...
Passenger side rear door window not working need to know how to take door panel off.
Thier is a Metal panel behind the door panel.
Both need to be removed
reverse to install
SKETCHLAB.com
Apr 12, 2009 | 2003 Volkswagen Passat
Window mechanism broke on passat
reverse to install
SKETCHLAB.com
Apr 01, 2009 | 2002 Volkswagen Passat
Take of drivers door panel
reverse to install
SKETCHLAB.com
Mar 21, 2009 | 2002 Volkswagen Passat
Passenger front power window
reverse to install
SKETCHLAB.com
Jan 16, 2009 | 2001 Volkswagen Passat
98 Jeep Wrangler door handle won't open door
there is a metal bar inside that clips into the handle they come off all the time there is a plastic clip that hold the 2 together it most likely has fallen off and into the bottom of the door you can put it back together easily if clip cannot be found you can buy them at local parts store for a couple bucks..hope this helps
Nov 21, 2008 | 1998 Jeep Wrangler
Need to know how to install exterior door handles
I'm assuming that you have the coupe not convertible since I've had same problem with my 97 Dodge Avenger and this is quite common from what I have heard. The handle is held in place by two 10mm bolts. One is easily accessable, located right beside the handle with the door open. The other is a little harder to get at. The first thing you need to do is remove the inside door cover, held in place by four screws and push in clips along the bottom that pull out easily. Two of the screws are visible and in the top corners of the door panel. One screw is located behind the inside handle and once removed the moulding comes off quite easily. The other screw is in the hand hold where you pull the door closed and has a small plastic cover over it. If you have power windows you are able to disconnect the switches once the panel is off. If manual windows, the handles are usually held on by a clip that can be pushed off with a screw driver allowing you to pull of the crank handle. The window needs to be in the closed position so you can access the ONE 10mm bolt holding the outer door handle. Once the interior door panel is off, if any clips remain in the door, take them out and put them where they should be in the door cover it won't go back together properly if you don't. Now you'll need to pull down the corner of the plastic covering the door, don't remove all the plastic just enough to allow access to the bolt. I used a small rachet to get it out. It is in a stupid spot with not much room but is doable. Once out, the handle is only being held by the lock rods to the handle and lock cylinder. The lock cylinder is held by a retaining clip which can be slid off allowing the cylinder to be pushed out. The other rod connected to the handle has a plastic clip on it holding it in place. This can be opened with a small screwdriver. Once opened the rod will come out easily and the handle should come off the door. The only problem reinstalling, that I had, was reconnecting the rod to the handle and found that if you unscrew the door latch, the whole mechanism can be moved down, giving you more freedom to work with the rod. You might want to do this before fighting with the clip holding the rod in place, just a thought as I got mine apart in 20 min. Installing the new handle is quite easy, just attach rod to the handle FIRST before anything else. Once the handle is back on the door the lock cylinder can be pushed back in, it just gets in the way if you put it in the handle right away. Hope this is of some help.
Oct 05, 2008 | 1997 Chrysler Sebring
Jeep 55117-JQ Stroller Logo
111 people viewed this question
Top Jeep Baby Gear Experts
Dorel UK
Dorel UK
Are you a Jeep Baby Gear Expert? Answer questions, earn points and help others
