Question about Garden
I have a kabuta tractor that got submerged in water and the engine froze up. i am removing it to replace with a new engine , i have everything apart but there is a shaft that goes from the front suspension through the middle of the pan on the exterior and goesback to the tranamission. i need to know how to release that shaft to get the engine out.
  • 61 Answers
Does it have u joints if so remove the u joints.
Posted on Sep 07, 2009
My simplicity riding lawn mower was submerged for about a half hour and will not start. what should I do?
change the sump oil , remove the plug and dry off, turn motor over with out the plug to empty water from the cylinder
remove fuel tank and empty water out , remove carby and empty water out
check all switches for water immersion
Jul 24, 2016 | Simplicity Broadmoor 20hp Briggs &...
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
Where is the cumputer in a toyota camry xle 2010?
everything will get soaked and the electronics will be affected , of which there are many. i'd recommend getting a good workshop manual for your vehicle because as you start removing parts to get to the electronics you will need some reference material, as the electronics covers various vehicle systems , was the engine running when it got submerged ? if so there could well internal water ingress so will need to check the oil , cylinders etc , got a big job on your hands , keep me posted if you wish
Jul 20, 2014 | 2010 Toyota Camry
Instructions how to change blower belt on a *.5 Poulan snow blower
remove the cover behind the engine then remove the top bolts that split the tractor half from the auger side tip the top apart
Apr 05, 2012 | Garden
Engine compartment partiallly submerged in water now wont start
1) you will need to drain the engine oil and refill it before you get it running again, the oil will be contaminated with water + change filter too.
2) you may also have water in the fuel, add a small bottle of methyl hydrate (gas line antifreeze) to your gas tank to neutralize the water.
3) remove your air filter and replace with a fresh dry one.
4) remove all the spark plugs and drape a clean white rag over the plug holes.
5) crank the engine over for about 30 seconds then have a look at the rag - if there are wet spots, there is water in the cylinders. repeat until you no longer get wet spots.
6) leave plugs out for a day for cylinders to dry out, then install fresh new plugs. as long as there is no internal damage, car should start now.
7) change engine oil and filter again to make sure all water is removed.
Mar 02, 2011 | 1996 Mercury Mystique
Kenmore heavy duty 80 series model 110.82682810 Series # C63203374. problem with cold water intake. Very low pressure. Checked everything up to inlet
This is commonly caused by a water inlet valve that has become clogged with sediment, rust or calcified deposits over time. If you live in an area that has hard water, or if you use well water, this can be a common problem.
You can attempt to remove the inlet valve and submerge in a 50/50 solution of distilled vinegar and hot water, or you can simply replace the valve. If you decide to attempt to clean the valve, submerge it for 30 minutes (do not submerge the solenoid contacts) and then rinse with clean water. Sometimes this can clear out the sediment and return them to normal operation. However, if this does not work, you need to replace the valve.
The following link explains how to access and replace:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
A replacement valve (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices differ between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
The part number for a replacement valve for the model you have listed is 285805. The average cost is about $30.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 20, 2010 | Kenmore 24032\24036 Top Load Washer
I submerged my 2006 700 king quad what to do? I turned off key but water filled everything. I have drained oil. Motor will turn over. I have not tried to Crank. What should I do
If water is in fuel tank, drain and refill with clean fuel. Replace fuel filter. Remove spark plug and crank engine over several times to clear cylinder of possible water. Clean and dry plug, reinstall, refill oil and try to start engine.
You may get a pleasant surprise.
Jul 19, 2009 | 2001 Suzuki Burgman 250
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
