Ok, well i have a 1986 kawasaki bayou 185, and i need a manual for it really badly because i need to know how much oil to use, what kind to use, and how long it should last because i think that i have a leak. i also need to to kno how much gear oil to use too. thank you! please give me the right answers
  • Chummy_57C
    Chummy_57C May 11, 2010
    Have you tried posting under Motorcycles? This category is for PC Desktops.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    You do know you posted this under computer repair..repost under correct subject.
    Sergeant:
    Champion:
  • 212 Answers
Check your dealer or E-Bay. usually 4 to 5 Qts for the engine check on the side of the frame somewhere closer to the battery or the other side there should be a plate on it which says what kind to use. I have a Honda and a Yamah and I use 10W-40 in them. It has to be thicker than car oil. where you put the oil in there should either be a sight glass or a dipstick on the cap. Hope that helps You out. Good luck
Posted on May 23, 2009
1988 klf300 bayou no spark, installed a new cdi voltage regulator,stator,and coil ran for four days and now no spark. what do you think is wrong.
Hi, Jeff sounds like you have a faulty wire connection somewhere otherwise the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Another no spark bayou any help left out there
Kawasaki Bayou 300 spark problems
https://www.tradebit.com/usr/valuablemanuals/pub/9003/1986-2006KawasakiKlf300Bayoufree.pdf
OEM Parts for Kawasaki
1988 Kawasaki Bayou 185 Owner Manual
Jan 14, 2017 | Motorcycles
Where is the fuse located on my 1997 Kawasaki bayou 300?
Hi, Edward for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere $8 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/98357-bayou-300-4x4-new-problem.html Kawasaki Bayou not starting
Kawasaki Bayou 300 service manual repair 1986 2006 KLF300 Download Manuals...
https://personalmanual.com/1997-kawasaki-bayou-300-owners-manual
Jan 14, 2017 | kawasaki Motorcycles
Kawasaki bayou klf300b atv centrifugal clutch nut removal
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Kawasaki despair not, for a mere $5 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/138652-bayou-220-primary-clutch-nut-removal.html
Project Bayou 300 44 Clutch Repair
Bayou 300 Centrifugal Clutch Endplay Question
https://www.tradebit.com/filedetail.php/118245427-kawasaki-bayou-300-service-manual-repair-1986-2006
Feb 28, 2016 | kawasaki Motorcycles
Kawaski bayou 300 stater wont engage engine all the time why
Hi, Gary you may have a starter solenoid or starter drive going south for more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
bayou 300 starting problem Kawasaki ATV Forum
1986 Kawasaki Bayou 300 Starting Issues
Owner Manuals Service Manuals Kawasaki Vehicles
Jan 25, 2016 | Motorcycles
What list of things that control my neutral light from coming on for my kawasaki bayou 220
Bayou 220 250 KLF220 KLF250 Kawasaki Service Manual ...
www.cyclepedia.com/...manuals/kawasaki...manuals/kawasaki-klf250-ba...
The Kawasaki KLF220/250 Bayou requires the valve clearance, engine oil and oil filter be inspected every 600 miles. Keep your Bayou free of problems and in ..
Aug 05, 2015 | kawasaki Motorcycles
How do i set the time on a1986 kawasaki 185
u cant rebuild a bike without a repair manual-clymer and haynes
Dec 29, 2009 | 1996 kawasaki VN 1500 Vulcan Classic
1987 kawasaki 185 bayou reverse light
No, the reverse light is only for reverse indication. If the light is coming on while riding in any forward gear there is a loose connection, probably where the reverse sender attaches to the transmission or the sender itself is malfunctioning.
Jul 08, 2009 | 1985 kawasaki KE 125
Computers & Internet Logo
2,894 people viewed this question
David Payne
David Payne
