Question about Kenmore Dryers
Can't open top console...to make repair
Took off external screws-no help-tried to pry side pieces off-snapped one clip off (rats!)-now job on hold and considering a pro to spend 30 sec.to show me a simple(?) solution for $100-can you help-save me $$ - ?
  • J.T. Galloway May 09, 2009
    OK-"slotted" means a Phillips screwdriver, I assume, because a flat (standard) screwdriver has no slots. Correct?
    Please be more specific. Description of tool and procedure was vague. Thanks.
    President:
  • 1,489 Answers
Don't know which model you have, but on many, the top pops up by inserting a large slotted screwdriver under each of the front corners and prying up.
Posted on May 09, 2009
  • Samuel Charles Spriggs May 09, 2009
    A slotted screwdriver has a flat tip -- it's called slotted because it fits screws with slots in the head.
    The objective is to get something in the seam between the top of the dryer and the bottom of the dryer, and force the top up -- at which point this will pull out the clips (which are in holes in the top edge of the dryer bottom).
    There is a clip on each side of the dryer top -- that's why you pry up at each corner.
Sears kenmore dryer model 4179842990
Big job.
The top comes open with a small screwdriver, or better yet a putty knife slipped to the right and left front corners and pried up. You have a plastic clip on either side of the front top which will snap open when pried.
Then, the front of the machine is usually held on with two screws that are inserted into the top front from the top sides, one screw in each side.
The bottom is easier, once the top screws are out, you lift the whole front panel off.
Down at the bottom of the front panel are two clips that go in two holes to hold the panel on.
You will also be unplugging the wire connector to the door switch.
We also had this happen, and if turning your clothes inside out or tying the strings doesn't work, we found to put such items inside a mesh "unmentionables/undergarments" bag stopped the problem.
Be blessed.
Apr 01, 2013 | Whirlpool Dryers
Small piece of cd broke off and is in the xbox need to open it to get piece out but do not know how to open the machine
you need a very fine flat head screw driver and a t10 screw driver
snap the front off the end that has usb
get a nail or similiar look on top and bottom air holes you will see a triangle filled holes these are where the clips are for the sides top and bottom
the back you will see 2 holes 1 end then 5 holes other end push in flat screw driver till you hear a click do this with all holes until back opens then undo clips at front
now you shold have the bottom off
6 t10 screws holding case back to your belly or nearset to you 2 end screws undo and middle 1 these are the long ones
then back 3 screws you will see from the left bottom screw and middle screw same across then right screw a bit furthe down towards you take these out make sure they are the long screws
lid should now be off
under front of dvd drive is silver tape undo this then lift out dvd rom and unclip leads from back of player then 4 pozi screws opens player
hope this helps
Mar 06, 2011 | Microsoft Xbox 360 Console
Durning the wash cycle the agitator does not turn,just a clicking sound as if it was trying to ingage. I don't know the model number and it is over 12 years old
you sent the correct model number,most likely you broke the motor coupling part number 285753A and it's around 20 dollars.shouldn't take no more than 45 minutes to repair.remove the two screws that hold down the top console,flip the console up and with a screw driver pop the two metal clips and disconnect the lid switch.pop off the two clips on the pump and pull off the pump,then remove the two screws and clips and slide off the motor and you'll see the coupling.tap on one side of the new coupling onto the motor shaft and the other part onto the tranny shaft and slide the rubber piece also on the tranny part of the coupling,line up the motor and reinstall all the pieces you took off and you should be good to go
Feb 21, 2011 | Roper RTW4300SQ Top Load Washer
How do I remove the door panel to repair the door opening device?
Hello, my name is Ben and I can help with this. If you have electric windows use a small screwdriver and pry the switch assembly up gently. Go in under that lip and pry upward. If manual windows, there is a clip that holds the crank handle onto a shaft, the clip is shaped like a C with the open end towards the end of the crank handle. If you push in on the door panel a bit you can work a very small screwdriver or an ice pick or other long sharp tool behind the handle and pry the clip loose (CAUTION, when released the clip will try to fly off never to be seen again, so be careful with it). Now look towards the front bottom of the panel and remove that screw, then there is one in the armrest. Then pry out on that triangle shaped piece of plastic at the top of the panel, it just snaps straight out.Now you should be ready to start prying the panel off, start at the bottom and work around, it will sound like you are tearing the panel as the fasteners give way, just go slow and they will come IF you have already removed the screws. Once all the fasteners are free just lift the panel up and out.
Jun 29, 2010 | 1999 Chevrolet Silverado 1500
How to dismantle console box of honda civic 2008
1.
Alright, let's just jump right into it. Get down and low and at the front of your center console you'll find two clips holding it in. There's one on the driver's side and one on the passenger side.
Okay so now how the *#$@ do I remove those clips? If you pull they don't come out...and if you pry you'll just scratch your console. Here's how: Look carefully and you'll see the center is a little circle. Gentley push it in...voila..off it pops. Repeat this for the other side.
2.
Alright now it's time to head to the back. You should recline your seats all the way forward and slide them up front. This will give you plenty of room to work. Get down low and you'll see a screw holding the back in -- once again you'll find it on both sides.
Simply take your Phillips head screwdriver to the ****** and unscrew it on both sides.
3.
Look carefully and you're going to see that the top of your center console is comprised of two pieces. One that stretches from the front of the console to just behind the shift boot. The second piece stretches from there to the back of the console.
The second piece is what we're going to remove. Here's how to do it. It's only held down by a few clips so all you need to do is pry it up. So whip out your flat head screw driver, or other prying device along with a cloth to prevent your crazy @$$ from prying up the plastic too. Start and the back and pry it up.
4.
You can theoretically now just pull the whole thing straight up. However what I found to be easier was to pry up one side and get your fingers underneath then pull from left to right (or vice versa) to pop off the front clips. The front clips tend to be in stiffer than the ones around the side and rear.
*POP* The entire center piece should now be free!
5.
Now you're able to lift the piece straight up.
Simply slide the piece up and forward taking care not to scratch anything
6.
Alright you'll probably discover you can't quite get it past the brake lever.
Yup...excellent deduction Sherlock..the gear shifter seems to be in the way.
7.
Alright time to move out of the way Mister Gear Shifter
Slide that baby into 1st gear (Make sure you didn't lower your hand brake!!!)
8.
It's free! Now you have room to work!
Okay now that the gear shift is in first...you have room to carefully slide the piece forward and out without scratching anything.
So now that you have the rear piece off, you want to remove the front piece right?
Well as you can see here, all that's holding it in place are these two screws on this panel.
Take your mighty Phillips head screwdriver and go buck-wild on those two screws
You've now successfully removed everything that's been holding the center console down.You should now be able to slide the center console back and forth.
There you should be able to remove it now..and you should see this
Oct 13, 2009 | Honda Civic Coupe
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
To remove radio on a 1998 Buick LeSabre describes removing a plastic wood strip in middle of dash. It does not however, explain how to remove this trim strip.
I have a 1995 and 1999 LeSabre and the radio removal is the same on both.
1. Carefully remove the AC vents from the dash.
2. In each of the AC openings are screws that hold the top of the dash trim in place.
3. Starting from the passenger door gently pry off the "wood" trim piece, It is held in place with metal clips and velcro.
4. Do the same as 3 from the driver side (short piece).
5. Remove the remaing screws from the bottem of the dash.
6. Move the Shift knob (requires key) all the way down.
7. Starting at each end of the dash slowly pry/pull each clip along the top of the dash from its mounting hole. Be careful not to crack the silver trim piece on the top of the dash (especially on top of the passenger airbag).
8. When the dash is free tilt the top in towards the car and wiggle it loose around the bottom (over the steering column) and the whole piece should come free.
This gives access to the radio, heater controls, speedo etc.
For the radio - three screws - antenna cable pop out. The harness needs a little more work. If your radio has a security feature (blinking light when car is off) make sure you know the security unlock code. Test the code before pulling the power to the radio.
Turn the radio over and carefully unlock the blue clip at the bottom of the plug. Then work the harness loose.
This sounds much worse than it is - it should take 15-30 minutes depending if you have all the tools close by. BTW those AC vents have a top and bottom - the larger hole goes on the bottom and they snap back in place.
Jul 03, 2009 | 1997 Buick LeSabre
Loose handlebars
Easy 1 min job but an hr taking chrome off. Here is the readers digest version. Start with the headlight off first screw under light on chrome trim. then pry it off. unfasten the screws holding light on about 7 screws, then unplug light. their is a chrome piece on the top of light chrome has a nut holding it on take nut off then lift that piece off. pop the piece of plastic off the key hole it prys off two screws under it remove them. that piece of chrom has a screw in it in front of handlebars you uncovered it when you took that chrome cover piece off. JUST loosen it. Now im sure you took off your windshield before you started so now remove your bolts that hold on the quick release windshield on both sides. Your chrome nacell will now split apart to show your 4 bolds that lock down your handle bar. See I told you 1 in job but hr to take off the samn chrome. When you put that ling cover piece of chrome back on ..NOT To TiGHt or it will snap the piece the plastic goes on. Hope that helps.
Jun 19, 2009 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Can not get the back off my washing machine
This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, there is a Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. NOTE: Inspect the motor coupling. If it shows signs of wear, this would be a good time to replace it.
10. Install the new Drive Motor. Make sure all the black rubber pads are on the motor (there are four of them). These help to reduce noise and vibration. Also, make sure the white cardboard piece that covers the bottom of the motor remains in place. This is a splash guard to prevent water from splashing into the motor in the event of a leak or overflow. Now, line up the motor coupling correctly and place the lower motor retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
11. Reinstall electrical connector to the Drive Motor.
12. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
13. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
14. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
15. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
16. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 26, 2008 | Washing Machines
Replacing a motor coupling
I'm assuming this is a Whirlpool or Kenmore model top loader washer (?). If so, replacing a motor coupling is not a terribly difficult process and its not expensive. The motor coupling itself only costs about $15-$20. The labor, however, would eat you up if you decided to have someone put in on for you. However, if you feel this is beyond your capabilites, don't hesitate to seek the proper assistance you need. If I'm correct in my assumption on brand name, follow these steps:
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, then lift up. The entire case comes off exposing the wash tub and components.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when it is released.). Once the top clip is released, the bottom one should come out fairly easy. The clips are similiar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with with a rubber bushing connecting the two. Once plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Make sure you replace BOTH halves of the coupling even if one side appears good.
10. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
11. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in it's keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top brakcet keyed into its slot and snapped back into place.
12. Reinstall electrical connector to the Drive Motor.
13. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
14. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
15. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, then forcefully push it into the opening on top of the washer. It will snap back into to place.
16. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
17. Reinstall console.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. If you have any further questions, please post back with comments. I hope this helps you.
PS If you need a part number, post back with your model number and I will get it for you. The part is carried by almost any appliance repair store.
Nov 05, 2007 | Washing Machines
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
