Question about Hayward Navigator Pool Cleaner
How do you change the pod shoes on a hayward navigator?
    President:
  • 1,489 Answers
Replace pads
Be sure that the old inserts from the old shoes have been removed from the pods. They often break off inside and have to be dug out. Once you're sure the holes are empty make sure the new shoes are properly oriented, as one of the inserts is larger than the other. This prevents the shoe from being installed backwards. You have to press pretty hard to get the shoes to pop in.
Nov 29, 2013 | Hayward Navigator Pool Cleaner
I had a Hayward Pool Vac for 11 years properly maintained, but never had to replace any stainless steel part. Thus, only one year ago, I replaced it with a late model Navigator. It stopped moving two...
Hayward navigators have a 2 year warranty on their cleaners. The springs, as of now, are not replaceable so you would need to replace the pod kit. This is under warranty.
May 02, 2011 | Hayward Navigator Pool Cleaner
Does not move even after replacing shoes
The other parts that need replacing about every 12-18 months are the wings, flaps, pods, A-frame, turbine and, not as often, the gearbox. Also, make sure you tighten the screws on the pods all the way or they won't be able to move the cleaner properly.
www.cpo2go.com
Nov 18, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator moves very very slowly. Pool Filter cartrage is clean & I have replaced the shoes, flippers, flaps & impeller bearings. Also tried different hose. Pressue on hose is about 12 to...
Make sure to keep the leaf canister and pump basket clear. Another thing to check is; make sure the screws that hold on the pods(the "flippers" on the sides) are Really tight. Those need to be cranked down pretty hard to ensure that they can move the cleaner along.
www.cpo2go.com
Aug 08, 2010 | Hayward Navigator Pool Cleaner
My hayward navigator just moves in a circle. I picked up the navigator and saw that one of the paddles is not moving. When i pressed down on the paddle that was not moving it starts moving but as soon as I...
It wouldn't hurt to replace the pods (paddles). Also, the wings, flaps, A-frame, turbine, feet(shoes) and the gearbox. All of these things wear and should be done about every 12-18 months, as needed. Before you do any of this, though, try tightening the screw on the pod that's not working. These screws need to be very tight.
www.cpo2go.com
May 20, 2010 | Hayward Navigator Pool Cleaner
Navigator not moving at all. Plenty of suction, legs are moving but navigator is not. Shoes look good.
Check the screws that are on either side of the pods. They are located underneath a white plug. They have a 1/4" head. You'll need a nut driver. Make sure they are nice and tight. Also, you will need to look at the a-frame bearings and check for uneven wear.
May 17, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
My hayward pool navigator does not move any more. I just bought it for two month
check for debris that may be stopping the turbine from spinning. If that is not it and the turbine spins freely, check the bearings on the turbine and a-frames. If you have a rough finish in your pool such as pebble tec, check the pod shoes for excessive wear.
Hayward pool cleaner wont move
sounds like the turbine or a-frame bearings are bad. A turbine kit with a-frames will be a solution. Also check the pod shoes for wear, should be a good 1/4" or better.
May 19, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
208 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
