Question about Quasar SP-3235 32" TV
TV want come on
I have a Panasonic, Model CT-36D12DF tv that will not power up. Need help & schmatic
    President:
  • 814 Answers
You can only get the service information from a pay for service. They will charge you money for a copy of the information.You can find the service information with the use of a search engine. Use the brand name of the television and model number,ask for service manual. You can call the Panasonic customer support telephone number and ask them where to purchase the parts and service information. The telephone number is 1-800-211-7262 between the hours of 9am-7pm EST. They will help you with the service information and parts. If you have never done this type of repair before you will need to upload the schematic or service manual and ask for help from one of the experience television technicians. The troubleshooting will start from the power supply and continue until you fix the problem. This will require tools, test equipment, and a work space to work on the television. You will want to visually inspect the circuit boards for bad components and test the one that are suspect. You will have to unsolder some components to test them. This may require advanced solder techniques. This is because the boards are layered and can be damaged if not worked on properly. Hopefully this problem is only in the power supply board. Which is the simplest repair. I hope this information helps you with your repair.
Posted on Jun 10, 2009
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
Mar 15, 2012 | Panasonic CT-27G14 27" TV
A narrow, white, horizontal line on a Panasonic CT-36D12DF model is all that appears-it costs $95 just to have it looked at in our are-please advise!
Your TV problem is usually because solder connections to the vertical output integrated circuit go bad. A few minutes with a soldering iron is a quick fix. It is possible that the IC or other parts have failed, but the soldering is so common it would be the best place to start.
I've been out of the everyday shop end of TV service for 10 years now, so I don't know what kind of rates are typical. Maybe there's another servicer you can call who has a more reasonable minimum charge. For big sets like yours people usually called for home service so we had a trip charge and minimum labor. If there were no other problems, your set would have cost $79 to fix. If that $95 charge is just to look it over and then the labor and parts are additional, you might want to consider a new TV. I've seen 42-inch LCDs advertised around here for about $600. If a repair is going to cost $150 or more, it might be better to put some extra toward a new one with a warranty.
Apr 12, 2010 | Panasonic CT25G7 25" TV
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
I need the remote code for a Panasonic TV
Hi sometimes things aren't so bad, if you can't solve your remote issue I'm sure the universal ones would work. Like me you can spend ages looking & trying to find out when it's just simple to replace it. Could check retailers that have repo's & see if there is one in their bundle. Good luck
Jun 01, 2009 | Panasonic CT-2017 20" TV
I need Panasonic CT36SL14 service manual
tv powers up but no picture or sound. DVD works great has great picture and sound.
Apr 02, 2009 | Panasonic CT-36SL14 36" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent ragingbass@comcast.net
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Quasar SP-3235 32" TV Logo
137 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
