Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Dell bluford forntpanel connection detail - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
I cant find motherboard driver of dell bluford e139765. can you please give me a download link of the drivers of this board?
You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Sep 06, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Driver bluford
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Dec 10, 2010 | Dell OPTIPLEX GX60 Motherboard
I am looking for specs for a dell motherboard e139765
Dell Bluford e139765 motherboard:
Chipset: Intel 845GL with ICH4 southbridge Socket: 478 CPU Support: s478 Intel Celeron and Intel P4 400/533 FSB (BIOS rev A04 or newer required for latest models) RAM Support: 2x DDR PC2100 128MB-512MB (non-ECC) Sound Card: Analog Devices ADI 198x Integrated Audio Form factor: Non-ATX LAN: Broadcom BCM4401 10/100
USB: 4
Nov 18, 2009 | Dell Computers & Internet
Bluford E139765 mainboard power panel connector
Look at the board really close you'll see it at the bottom right corner, SPKR, RSW, PSW, and so on, try one at a time, until you get it
Jul 16, 2009 | Computers & Internet
Front panel usb connection detail
To connect the front panel usb you have to open the cpu cabinet and on the motherboard you will find the usb pins where it will be written Front_USB you have to connect the front panel usb wires to these pins you should see that thier will be a no connection pin at one end which you have to plug carefully
May 09, 2009 | Computers & Internet
Model name BLUFORD. E139765 motherboard. I need J16 pin layout for the power switch, reset switch, etc. Dell is not very helpful with this paticular board for some reason. Thank You for any info. DW
This is what I found after extensive searching,
......................O
.PWR LED- O O
.HDD LED- O O HDD LED+
.................... O O
.................... O O PWR LED+
...PWR SW O O PWR SW
.CON CNT O O CON CNT
Looks pretty lame, huh? I found this on Dell's Community Forum.
I gather, this motherboard was used in the Dell Dimension 2350.
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Looking, at what Dell has for the layout of the Dimension 2350 motherboard, there are 20 pins in the J16 header, just like he has crudely shown above. I don't see one missing in the corner, though. Of course, the link above is a crude example from Dell.
This person stated it was for the J24 header on the motherboard. Also stated that it was the Front Panel I/O header. (At least that's what was stated) I believe he was confused with the Control Panel header J24. Hopefully it is for the J16 Front Panel I/O header, as it has the Power On switch, HDD activity LED, Power LED, and so on.
Indications are that the O's represent the pins. There was a statement of taking -> Note, that there is a missing pin in the upper corner, and this orients the connector view, Orients, how you are looking at the connector. Only you will know for sure. I don't have this motherboard in front of me. Dell ISN'T giving ANY info out.
This person had the Bluford E139765 motherboard, in a Dell Dimension 2350.
The statement was also made, that there is a Brown jumper wire that connects the two CON CNT pins together, but didn't know if this jumper is required, as this person is putting this motherboard, into an aftermarket computer case. (?)
Solution?
What I would do.
I would have the power supply plugged in. I would use an LED lamp, with two wire leads attached to it. Leads of about two inches long, or more. (Borrow one out of the Front Panel, or from another parts computer?)
Twist the ends of the lead wires tightly. I would then touch the leads to two pins. Should they be power Out pins, (HDD activity lamp pins. Power LED pins, and so on), the light will light up, and not short out the two pins touched.
(If the LED light doesn't light up, no biggie. It just means the wires need to be reversed. Bear this in mind, when you go to hook the LED's up)
When the two pins for the Power On is found, the computer will turn on.
Judging by the crude diagram the missing pin is on the upper right.
Only you will know for sure, as the J16 header should have a flat place in one corner, where a pin would go. NO pin.
If so, this is what I see.
Processor to the left, PCI slots to the right, J16 header on the right, above the PCI slots. The header goes along the edge of the motherboard, lengthwise.
I'll number the pins like this.
Starting at the Top Left, and going down the Left side.
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Starting at the Top Right, and going down the Right side.
NO pin, (Would have been Pin 2),
Pins 4, 6, 8, 10, 12, 14, 16, 18, and 20
Pins 3 and 4 are for the Power LED. (Confusion here)
Pins 5 and 6 are for the harddrive activity LED. PIn 6 is for the + wire/
NO connection to Pins 7, 8, 9, and 10
Pins 11 and 12 are for the Power LED.
(Which ones to use? Pins 11 and 12, or Pins 3 and 4? I leave it up to you to test as the computer is on, and see)
NO connection to Pins 13 and 14
Pins 15 and 16 are for the Power On switch.
NO connection to Pins 17 and 18.
Pins 19 and 20 are for that jumper wire he mentioned. I would try it without it. If the computer doesn't come on, or something doesn't work, like the harddrive for example, I would unplug the computer from power, then attach this jumper. Plug in, and see if everything works.
Apr 19, 2009 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
394 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
