Question about Refrigerators
Overload relay bad ordered new one part# 67005560 pulled old relay out and it has different connection did I order wrong relay?
I ordered a new overload relay part #67005560 for my Maytag MSD264RHEW and when I pulled the old relay out the connections are different. Did I order the wrong one?
  • 159 Answers
Normally it a replacement part but overload is a clickson
Posted on May 22, 2009
The start relay on Kenmore model 596.58642890 replacement question
The original relay switch has 3 terminal contacts on the compressor side. On the wiring side it has 4 contacts... 2 are start capacitor connections and two at the bottom of the relay are the A/C 110-125 volt line in connections. The replacement part you bought is a genericreplacement for the ref. The correct substitute part is W10189190 . The two wires for the original relay in the top horizonal position evenly spaced apart... ignore the 2 wires. They are wires to the old start capacitor mounted somewhere near the compressor. The other two wires are important to configure them properly. One may be blue and the other red. Here is a cheap way to know which is the right configuration... Use a volt ohmmeter and check the continuity from the refrigerator ground terminal on the A/C line cord or chassis to both A/C line in wire connections to the relay. If the ohms are zero or very near to zero then that is the ground/ aka neutral wire. The neutral wire connects to the bi-metal overload protector built into the relay. That is the bottom center connection terminal on the compressor. The other A/C line in wire is the hot wire and it connects to the Start/ Run connection on the new relay. http://www.appliancezone.com/ShowProduct.aspx?ID=28271
OR
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/10097202/0046/596/Model-59658642890/0582/0165000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P8090243&diagramPageId=00010&productTypeId=&searchModelNumber=59658642890&subCompDesc=Machine%20compartment/muffler&brandDesc=KENMORE&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&blt=11&shdMod=59658642890&keyId=251
Feb 07, 2014 | Kenmore Refrigerators
I ordered the relay/capacitor part #67005560 for my Amana refrigerator Model # BZ20QL. The replacement part does not look at all like the original parts.
Talk to your supplier, the part could be OK. since in 20 years, the design is changing. Did you get some instructions with the part?
Mar 15, 2013 | Amana Refrigerators
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
I'm getting a wierd sound coming from my JBL2088HES refrigerator. It is a buzz like an electric shaver followed by a click. It seems to happen in 3 min intervals. Any Idea what it could be?
Kevin,
It sounds like it could be the compressor overload relay or the compressor itself. Lets hope that it is the overload relay, most compressor replacements are very expensive.
The overload/relay isn't very expensive and replacing it will be cheaper than calling a repair tech to tell you if it is the compressor or the overload/relay.
This is a relatively simple repair, if you look at your compressor you will find two wires connected to a small box ( overload/relay )
To remove the overload first you must remove the metal retainer by unhooking it with a pair of needle nose pliers.
Now remove the overload relay by pulling it away from the compressor.
The relay for your refrigerator has a capacitor connected to it, the capacitor and the relay are sold as one piece part # 67005560.
all that you have to do is remove the old relay with the capacitor from the wires by pulling the plug off and connecting the new overload/relay/capacitor to it, reinstall the relay to the compressor and you are done.
Good Luck
Check us out at www.centuryappliancerepair.com
Dec 10, 2009 | Jenn-Air Refrigerators
Compressor makes a funny humming noise and frigerator gets warm , if you tap the compressor it works fine for awhile, but after awhile I get the annoying humming sound again and the temp in the...
your loosing your relay or overload,,, tapping works hey...... like and old chevy starter
anyway
look at the compressor you will see the parts im tlking about
relay and overload
pull these off and ohm them out
sounds like thay are going bad
very easy reapir go to
www.appliancepartspros.com
jujst type in your model numnber
and seacrch the compressore=
compartment
order and replace you should be fine
Oct 24, 2009 | Refrigerators
Freezer buzzes then clicks off maytag model #msd2651hew
Replace the overload/relay . Part number 67005560 . You will need to pull the refrig out and remove the bottom panel . This piece , plugs onto the compressor , with 2 or 3 wires attached to it . You can easily replace . While back there , you may want to clean the "square" coils , of dust , lint , etc .
Oct 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Model maytag pbf2255hew freezer and refrigerator not cooling compresor on and off every 3minutes
Pull the refrig out , and remove the rear panel . Is the fan cooling the compressor working ? If not ,replace the fan motor . If it is working , I would say the overload/relay is bad . Pt # 67005560 . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . Easily replaceable and not at all expensive , if you change it yourself .
Sep 27, 2009 | Maytag Refrigerators
My model PSD262LHEW refrig freezer stopped cooling. the motor still runs
By your question , motor still runs , which motor ? If the freezer motor is the motor your refering to , then check the compressor to see if it is running . If not , then the overload/relay is bad pt# 67005560 . This is the piece plugged onto the compressor with 2 or 3 wires going to it .
Jul 30, 2009 | Maytag Refrigerators
Refrigerators Logo
638 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
