Question about Philips Magnavox 51MP392H Rear Projection Television
51MP392H rear projection - flashing on/off button
I have a magnavox rear projection tv.  The on / off switch is flashing and the tv won't turn on.  I have unplugged and the problem continues.
  • 1 more comment
  • 3monkeys Feb 06, 2008
    Your TV's power regulator may have a problem. But first check if your voltage is sufficient on the wall socket. Try using other electronic appliances there.
    I found this on the site..did you ever find the answer? We are having the same problem
  • fulby2001 Sep 07, 2008
    I had the same problem. It was still under warranty, and they had two replace two of the three boards inside. However, my TV makes popping noises when I watch hdtv, and the two new boards haven't solved this issue.
  • Anonymous Sep 11, 2008
    My TV will not come on and the power button keeps on flashing. I unplugged the TV and plugged it back in again and the power button is still flashing.
  • Philips Master
  • 3,459 Answers
Power light but no audio/video is fairly common problem. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Posted on Aug 06, 2008
Why my tv turn off on its own
Most projection TVs that turn themselves off will flash a code on the power light (or a light). (Usually 2 to 9 flashes, a pause and then repeat). Give this code to a Magnavox service center and they may be able to say what is wrong.
Mar 31, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips projection tv wont turn on and power button flashes
There is no Code for tuning power off/on You may have bad STKs. If 1 of these ics goes bad it will shut set off so replace them both,.
Dec 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 55p8288 tv not turning on
My problem is the same as the other two ppl. The Tv does not come on only the power button keeps flashing on/off.
Nov 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 54" Projection screen TV
Replace your STKs 392-110s with 180s if 020s go with 040s
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Replacement Lenticular Screen for Magnavox TV
The screen is available from tritronicsinc.com for $239.44 using part number: 483536037078
Dan
Sep 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox rear projectin television
Check the fuse first, if you are luck, probably you only need to change the fuse otherwise you probably need a new TV.
Turn off home electrity power or unplug all the expensive units when it is lighting to protect them.
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
183 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
