Question about Gateway MX6920 Notebook
The mx6920 laptop screen goes black
I have had the mx6920 laptop for 3 years and just recently the monitor has been going black screen, periodically and with no descernible pattern. The CPU is still running, but I have to do a hard reboot to get laptop running again.
  • fougzki May 11, 2010
    Try to connect secondary monitor. And run dual monitor. Then if the screen goes black and to secondary does not. Then screen has the fault.
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6000 about 3 years old. When I boot up, sometimes it goes through the early Windows XP screens and then goes to a blank screen. It indicates that activity is going on but cannot see it on the...
The screen cable is most likely damaged. Try connecting an external monitor. If it works, you need to take the computer to a repair center to have the cable changed.
Aug 24, 2009 | Dell Computers & Internet
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Gateway mx6920 powers on sounds like its booting but screen is bl
It's most likely your motherboard. It's really common with the MX series.
I'd pull the hard drive and sell the laptop for parts on eBay "as-is".
It's NOT the power module.
Or you could always swap the motherboard but in my opinion it would be best to just invest the money into a new laptop instead of this one.
Best of luck!
May 11, 2009 | Gateway MX6920 Notebook
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
Gateway MX6920 Notebook Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
