Question about JVC THS55 System
I need a power cord that goes from the tv to the woofer for the jvc suround sound system. it is round shaped and has a lot of prongs inside. I believe I broke some of the prongs. Both ends of the cord has the same ends
  • 163 Answers
Keep your eye on ebay.
Posted on May 09, 2009
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
I am trying to convert a three wire prong to 4 on my whirlpool dryer.
Inside the back of your dryer is a strip where the electric cord fastens on, behind a squarish panel about 5" X 5" sort-of.
There should be 3 screws/nuts in a row of the cord to hook to.
The right and the left screw/nut is HOT, for the black or red wire on a 4 wire cord. It does not matter which gets black and which gets red, they are both HOT. These wires are attached to the FLAT lugs on the plug end of the cord, NOT the "L" shaped or the round lugs.
On a four wire cord, there are also a white wire and a blue or green wire. These are both ground wires. The white wire goes to the middle screw/nut on the 3 connection bar of the machine, and the blue/green wire goes to the body of the dryer itself. (Use one of the little screws along side the opening for the wire.) The white wire goes to the "L" shaped lug on the plug, and the green/blue wire goes to the round lug of the plug.
Be blessed.
Jun 23, 2013 | Dryers
Fisher paykel DegX1 replacement cord istallation
Well, of all the problems, you selected an easier one!
Your four-pronged cord has two straight lugs on it.
These are "HOT".
You also have two more lugs, one is round, and one is "L" shaped.
Those two are "ground".
Here's how they attach.
Inside the rear of your machine are 3 screws/nuts in a row.
The outside 2 screws/nuts are both HOT, and it doesn't matter whether the red wire goes to the left one or the right one.
Same with the black wire.
Goes to the left or the right.
The center screw/nut is for the white ground wire.
The other wire (maybe green or maybe blue) should be attached to the side of the hole where the wire enters the dryer.
That one should be put under a screw on the side of the hole, fastened to the "case" or the body of the dryer.
Be blessed.
Mar 20, 2013 | Fisher and Paykel DEGX1 Electric Dryer
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
No power to my rca tv model number F27733SB. the slot for the power cord that goes from the tv to the wall is missing a 3rd prong on the "male" side that is actually in the Tv. The unversal...
Hello
Only a two prong wire is needed for any TV to switch on. A three prongs are used for electrical equipments like Mixie, Grider and son, to get onw of the prngs to earth point to avoid accidents due to electric shock. Even though, your tv is provided a three prong wire for its power supply, only two of them are used inside the tv to work on. One amoung them are set free inside the TV. You kust try by replaceing the present wire by a new one. If the problem perists, inform me through Fixya, with as much as details you can send. OK.
Nov 06, 2010 | RCA F27733SB 27" TV
I am connecting a new dryer cord. How do I know
Look for a stamp mark next to terminals on dryer. red and black are hot green is ground. OR flat prongs are hot and "L" shaped or round prong is ground
Nov 04, 2009 | Kenmore Dryers
Lost power cord for speakers where do i get another.
RadioShack or Best Buy. Target might even have it. Just remember the shape for the plug that goes into the speaker. It will only cost at Max, $10 Chances are its either a round side and square side, or a three prong polygon.
Sep 19, 2009 | Audio Players & Recorders
Can you hook the jvc th-m505 to your tv for suround sound? and if so how?
your tv needs to have audio outputs... run the rca wires from the out to the in on your system in the aux 1 or whatever you choose for your tv
Jul 30, 2009 | JVC TH-M505 System
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Jun 08, 2009 | Electrolux Dryers
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
JVC THS55 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
