Question about Samsung TXN2726 27" TV
Old Samsung portable TV
Our TV worked fine, and now it won't turn on, it just flashes a small red light on the power, if I hold the power in, it shuts off (the light) push power and light starts flashing, it's like it's in a sleep mode.  But it won't turn on at all.
Any suggestions?
  • Kmottl Jan 28, 2008
    I have the same problem on my Samsung TTC1350
  • ca1103 Apr 25, 2008
    My Samsung tv was working fine. It is only 2 years old. I can't get a picture or sound, only blinking red light for the power button.
  • 6 Answers
Obviously the problem is with the SMPS unit, could be a faulty switching transistor.
Posted on May 11, 2008
SOURCE:
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Mar 02, 2013 | Samsung Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
61" samsung DLP 3 years old. Keeps turning off by itself.
Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
I had a controller working with a certain t.v. and want to program it on a new samsung tv i just got, instead of using the old tv
You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Feb 02, 2009 | DISH Network IR Remote Control
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung TXN2726 27" TV Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
