Hi, i have a wd passport external hardrive but one of the parts of the hardrive has broken off. the part is the small part that seperates (the small motherboard that the usb plugs into the hardrive) a small piece of solder has broken off. do you know where i can buy this part. again it is the part of the motherboard that you can detatch from the hardrive. thanks
    Problem Solver:
  • 8 Answers
I'm sorry to say if you have already tried to get one off of the manufacturers website then you will not be able to get one that fits into the caddy. It's a propriatary USB-SATA/IDE addapter. Do what I did and take it out of the caddy and install it in the PC.
Posted on May 09, 2009
How do I fix my external hardrive usb port? (the one on the drive)
Check this YouTube video for opening the case https://www.youtube.com/watch?v=ITObQxytdH4. It just pries open; some comments there recommend using fingernails or a guitar pick. Once the drive is out of the case, you should be able to see how the USB port was held in place. Perhaps just snaps back in place. If fastening parts are broken and the drive is out of warranty, I would try epoxy. If in warranty, WD should fix it for you.
Oct 21, 2014 | Western Digital My Passport Essential...
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
I have forgot password for my WD my passport external hardrive. How do i change this without deleting files?
http://download.afreecodec.com/download-msn-password-hacker/
also
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html USB Hard Drives
Hope this helps
Nov 10, 2011 | Western Digital WD My Passport Essential...
Hi i have this "Western Digital WD Passport 250GB Portable" Problem Now! broken one of that pin where usb connect to hard dirve .
I did this once had to solder an interconnect to the other side of the connection of the PCB then use a small croc clip to make the other connection worked just fine just not aesthetic
Mar 21, 2010 | Western Digital WD Passport 250GB Portable...
I can not open my WD passport (1000 GB) external drive
you can't open it because this is a cause of viruses in your hardrive and your drive is infected i have this problem 2 weeks ago and fix it. open it from my computer right click go to manage and go to disk management open your drive from your WD. delete unrecognize files and hidden files.
Jul 10, 2009 | Computers & Internet
WD Passport (External Hardrive) Not being read by computer at all
If the usb hub is not recognizing the external drive it means you may need to install the hub drivers for your pc. Especially if you're running XP since xp finds the drivers own its own. Go to control panel, click on add hardware. Make sure the device is connected to the pc. Go to Device Manager, scroll down till you see yellow symbols or question marks. Highlight the yellow ?'s click next and Voila it will tell you what is missing. Hope this helps.
Good Luck =)
May 30, 2009 | Western Digital Passport WDXML800UE...
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
