Question about Samsung HP-T4264 42 in. Plasma HDTV
Set comes on an plays 15 sec good pic an sound--cuts off an stays off 15-20 sec and cuts back on with good pic an sound--it just keeps cycling on an off like this--any ideas on problem??
Need to reboot unit
Posted on May 09, 2009
Lg32lc46 lcd tv cuts off after a while
It sounds like a back-light inverter board fault. Check it. Replace it if needy. Normally, these boards has no repair. Replacement only can be done. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 24, 2013 | Televison & Video
After a power surge yesterday my hotpoint dishwasher is doing this halfway through the cycle. It doesn't finish the cycle - water stays cold and it doesn't dry the dishes - any ideas's? The model is
Try cutting off the power to the dishwasher at the breaker box to reset the memory board ( for 15 sec.) then turn the breaker back on. If this did the trick good if not then the power surge may have over powered the board inside.
Oct 14, 2012 | Dishwashers
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Master 160,000 btu will not stay lit
pull out flame sensor and sand. Re install and call for heat
Jan 21, 2009 | Master Heaters 160-IF
XL-2100U lamp cycles on and off
Hi
I recently had a similar problem after replacing my lamp the set would work for 22 mins then go into standby for 30 sec then come back on, then repeats, I decided to experiment with the lamp housing, I removed the new lamp, unscrewed the top of the lamp that holds the actual bulb then switched out the main housing (bottom part) with the original housing, that seemingly has corrected my problem, you may want to try if the replacement lamp did not come from Sony...good luck
Sep 10, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
No video, no sound, power button light on constant, front panel light flashing
have a good tech diagnose this and there is a commom problem with this set in the power supply but is not nessesary to junk the set some places rebuilt light engine if thats the case
Feb 08, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sound not working for bioshock for 360
http://support.microsoft.com/kb/909338
Dec 02, 2007 | Microsoft Xbox 360 Console
Samsung HP-T4264 42 in. Plasma HDTV Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
