Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
Walkie talkie wont communicate
Have two walkie talkie never used power up just fine but I cant get them to communicate if I push the button they do not transmit, but this is not new they never have. I just got tired of playing with them. What can I do ?
    New Friend:
  • 160 Answers
Are you on the right sub tone
Posted on May 09, 2009
    Master:
  • 379 Answers
Um if it dont transmit then take it apart if you know how to or
let me see it
i can fix eny walkie talkie
Posted on Sep 14, 2009
I would like KNOW how to use a kem P25703 WALKIE TALKIE
Different Motorola model walkie talkie instructions shown below at the internet link.
You need someone else to have a walkie talkie to communicate with them.
https://www.buytwowayradios.com/products/motorola/manuals/MH230R-manual.pdf
Apr 29, 2018 | Radio Communications
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
Why does one earphone work fine on my walkie talkie but the other one you have to press the mic button on the wire and also have to push the talk on the walkie
It seems not to be the earphone. It is likely the audio jack you are plugging into. Type or brand would help. Generally, audio jacks are poorly installed. Or they are are on top of a radio, inviting dirt, debris and water into them. Tap the radio with the issue, audio jack down and see if anything falls out. Then, if possible and at your own risk, use some rubbing alcohol and try to clean it. This may require a very small tool and you may damage the jack beyond repair. Our shop takes radios apart to perform these tasks, plus we have some tiny tools. Even then, we often replace the actual audio jack. They fail.
Jan 08, 2016 | Radio Communications
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
Both walkie talkies are on the same channel, but will not transmit voice messages
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 05, 2014 | Motorola Walkie Talkie 2-Way Radio
. Keeps shutting off
This is a sign of a bad or low battery. Try swapping batteries with a known good unit to see if the problem is solved. It takes more energy to transmit than to receive, so as you described a radio can receive messages, but then when you go to transmit and use more energy the battery will not have enough power to do so.
Best regards.
Apr 01, 2014 | Motorola MR350R Two Way Radio
Portable motorola gp 340 can receive but cannot transmit
Don't know your capabilities but if it were me I would open the phone and check the contacts for transmit button. Sometimes contacts get corroded and need cleaning or it just may be no connection at all and a adjustment of the contacts will resolve the issue.
Mar 10, 2014 | Motorola Walkie Talkies 2-Way Radio
I cannot get my bellsouth walkie talkie model 2290 to unlock from a channel
The manual says to press and hold the MODE button for 5 seconds turn on or to turn off the LOCK mode. When locked, it prevents you from accidentally changing channels.
Jan 05, 2013 | BellSouth 2290 Walkie Talkie FRS/GMRS...
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
1,837 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
