We have an older model (58SG100251) installed in the attic. With the thermostat set & turned on nothing happens. A new blower motor was installed last year.The t/stat is a ritetemp digital. I,ve c
We have an older model (58SG100251) installed in the attic. With the thermostat set & turned on nothing happens. A new blower motor was installed last year.The t/stat is a ritetemp digital. I,ve checked all c/breakers but still nothing happens.
  • 8 more comments
  • tbooth683 May 09, 2009
    Nothing happens when the t/stat is changed from 1 setting to another & the door only has 2 screws & a switch inside toward the upper lefthand side.
  • tbooth683 May 11, 2009
    Both c/b's have been reset & are holding.
  • tbooth683 May 12, 2009
    I get nothing with the switch to fan only.
  • tbooth683 May 15, 2009
    Power from the plug (house) to unit reads 115v. What I'm assuming is the xfmr has 4 wires;bl,bk,wh & yl. The relay ( exposed copper coil ?) has 5 wires;rd,gr,bk, wh & bl. These wires are all wire nutted to a rats nest of more wires inside the housing. The diagram shows light lines, I assume are the 24v, & heavy lines being the house current. The colors don't match to the components by the picture. It would be easier if the wires had #'s like on aircraft.
  • tbooth683 May 23, 2009
    This is a Carrier unit. Up until a month or so ago, the heating portion worked just fine. Now nothing works when the t/stat switch is moved to any position. There is no fuse on the outside of the unit, the door is correctly installed & the outside unit does not come on.
  • Dennis Boxerman May 11, 2010
    As a general rule, the light lines could be what is called "field wiring". Which means that this is the wiring that is done by the installer. Look closely at the legend for clarification on that. The transformer has to have a minimum of 4 wires-2 for incoming power, and 2 for out going power. Most all transformers have what wires are what printed on them. If not,it should be on the diagram. If it is readable. No too worried about any relays yet as we have not established as to whether or not you have control voltage (24v). We have to establish that first. Take a good hard look at the transformer and/or diagram and see if it indicates what the wires are for it. You have to check both sides of the transformer for power to determine if that is your problem.
    By the way, what is the brand name on this unit?
    O.K.
    Now, with no indoor fan, this tells us either you have no power to the indoor unit (single pole breaker-120 volts), or the transformer is not putting out the necessary 24 volts.
    Look around the indoor unit to see if there are any switches that may look like your standard light switch. This may be used as a power disconnect for the indoor unit. Be sure it is on. If so, then we are looking at finding the transformer. If you can read a wiring diagram, great. If not, kill power and open unit. Now look for your thermostat wires that come down from the thermostat to the indoor unit. They may go to a circuit board with terminals and letters. The transformer should be in that immediate area. Usually has one black wire and one white wire on one side and the other side may have several different color wires coming from it. There are too many combinations made by too many different manufacturers to be exact on this. It should have a lable saying that the input voltage is 120 ( or higher using different color wires), and the out put voltage is 24 volts. It will also refer to V/A (volt/ampers). This or the circuit board may have a fuse on it. Check it to see if it good. Use a meter. If in doubt, change it. Look in the transformer to see if it has a black button on it. It may be a manual reset to prevent and overload condition.
    Check this out and get back to me.
    O.K.
    Step one. On the t'stat, see if you can just turn on the fan. There should be some way to switch on the indoor fan. Some have a switch that says "FAN-AUTO-ON" Set it to 'ON" If fan comes on, this verifies that you have power to the indoor unit and that low voltage is present. If no fan, we need to dig alittle deeper. This elimiates two things. Do this and get back to me.
    We can do this.
    Is there a display on the t'stat? If not, look for lost power to the air handler. This us usually a singe pole breaker whereas the outside unit uses a dual pole breaker. Check this out and get back with me.
    Thanks.
  • HANK MCNEIL May 11, 2010
    do any tstat settings make anything happen? Did you check the fuse on the side of the furnace? Are the doors on the furnace correctly?
    Problem Solver:
  • 16 Answers
Possible fan relay is defective, does outside unit come on ?
Posted on May 21, 2009
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glow or...
Smartvalves are tricky and a certain sequence must happen. Without going into this in depth, try this:
Install new smartvalve
Set thermostat to the off position
Kill the power to the unit
Restore power to the unit
Turn the heat on with the thermostat
In this order!
Aug 29, 2017 | Honeywell Heating & Cooling
Central heat works fine, but a/c does not come on and the blower in the attic doesnt come on when switched to cool only for heat. Touch R & G wires together nothing happens. R & Y nothing happens....
Probably not in the wiring unless you did it yourself. Most likely it is the outside unit that is not coming on for any number of reasons. Call a tech to trace the problem.
Apr 21, 2013 | Heating & Cooling
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Have a Janitrol central air system and the unit outside comes on but the fan in attic does not always come on. If I go to the thermostat and manually turn it from auto to on it comes on. Any ideas about...
If the blower is working with the thermostat in the ON position that tells you that the fan motor works. In the AUTO setting... the system in controlled by the contacts in the thermostat. 1. The thermostat contacts might not be closing. 2. A contactor( or relay ) in the air handler unit(inside unit) might not be closing to send the signal to the fan motor. It sounds like a thermostat or relay problem to me. You can email me at Starztruck4u@aol.com if you have more questions.
Aug 05, 2010 | Heating & Cooling
Blower never stops. AC outside jammed to stay on???
You need to call someone who truely knows what they're doing. From your decription, the person you had out should not be working on units. You have a problem most likely caused be the person that installed the new motor and these units are not designed to be worked on by the homeowner. There are hazards that could cause damage or injury.
Aug 18, 2009 | Goodman CLJ36AR42 Air Conditioner
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
Attic fans
I just fixed a Broan-353 with a similar problem - the fan was short-cycling, turning on and off within a minute or less.
These fans have a thermostat which is designed to turn off 10 degrees below where it's set to turn on. Apparently, one failure mode is this temperature delta stops working I've had this happen twice, each time after about 3 years.
Replacement thermostats are available from Broan for about $30 http://parts.broan-nutone.com/broan/Shop It's a 10 minute repair if you have easy access to the fan.
May 23, 2008 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Blower in Attic not running
inside unit has fan control relay , either on control board or can be separate ,except for the 24 volt transformer and the t-stat the units operate separately concentrate totally on the inside unit this is where the problem lies
Oct 23, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
558 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
