Question about Roper RAS6233KQ Top Load Washer
Washing machine is adjatating but not spinning
  • Roper Master
  • 8,220 Answers
Posted on May 09, 2009
GE Washer wds2080d8ww will not adjatate
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 22, 2011 | GE Washing Machines
Washer spins but doesn't adjatate
could be a bad transmission , clutch. basket drive, or timer. no brand name or model so just common issues
Jun 03, 2011 | Washing Machines
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
Our whirlpool washers agitator doesn't agitate during the spin or wash cycles
I would asume you mean it does not adjatate during the wash or rinse cycles.If it fills and you can here the motor run after it fills/then it drains and does not spin and fills again for the rinse but does not adjatate ? I would guess you have a broken motor coupler ..Most shops will do that repair for under 100.00....If I had more info I could be more sure...anyhow if more info is needed just repost....I hope I help you if I did please give a vote...thank you good luck
P.S mod # helps so much
Feb 02, 2011 | Whirlpool Washing Machines
Where is motor thermal cutout?
built into the motor . odds are if your not getting a spin or adjatate from the washer it is the motor control or door lock mech
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
My pav2300 fills spins but will not adjatate and makes noisewhen it trys...thanks mike
It sounds like the belt is all right, maybe the drive clutch is broken. It has plastic lugs that break off. One piece of plastic sandwiched between two pieces of rubber.
Oct 31, 2009 | Maytag PAV2300 Top Load Washer
Adjatates but wont spin, what up?
if you have a top loading washer your problem is the lid switch , it is not reading the lid being closed. easy fix. let me know if you have any other questions.
Phil
Jun 10, 2009 | Washing Machines
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Adjatator not turning
your pump or outlet pipe might be blocked if n ot then the pump will be faulty
Nov 19, 2008 | Hoover Washing Machines
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Roper RAS6233KQ Top Load Washer Logo
262 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
