I have a PHASER 8550DP that out of no where gave Fault 37,008.44:19678 Xerox tech in India was useless saying the computer showed I should turn it off and on and/or unplug it. REALLY? that is the first thing most people do. Anyway it still says that Fault and I dont know why. Xerox wanted to charge $300 for the 1st 30 min for a tech to come out.
  • 10,515 Answers
37,008.44 Preheater disconnect. The preheater is not drawing the expected power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS’s) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report preheater errors (37,002.47 thru 37,012.48). Verify the AC power source prior to troubleshooting a printer exhibiting any of these errors.
I've sometimes seen a piece of paper or dried ink(wax) stuck in the pre-heater cause this error. If you open the front cover, remove the 2 plastic guides (one is white, the other is green) the pre-heater is right there. Unplug the 2 connectors, slide the 2 spring loaded restraints inwards (towards the middle) and the pre-heater will slide right out. Unplug the printer AC cord first.
You don't need a UPS with these printers as they have a really good switching power supply. You could plug it into 400V without damaging it. So they say.
Hope this helps.
Thanks for using "Fixya".
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 09, 2009
Xerox 8550 error code 19,004,40
19,004.40: The printhead and the electronics module do not match. Contact escalated Service Support Representative for information to clear fault.
May 31, 2010 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP printing duplex
are you not able to get even the print menu?
Jul 22, 2008 | Xerox Phaser 8550DP Printer
I'm looking for instructions to install the control panel for a Phaser 8550 DP.
Xerox has a video on how to install the control panel at:
http://www.office.xerox.com/userdoc/P8500_8550/8500_8550_Web/videos/controlpanel_installation.html
May 28, 2009 | Xerox Phaser 8550DP Printer
Installation of Phaser 8550 DP on network
This is no problem for someone with even a little networking knowledge, but it would take longer to write the instructions here, than it would to have someone spend less than an hour configuring it on site. That's my recommendation
May 19, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
Phaser 8550 Panel
It comes with directions. It is real easy to replace. Just call 10800-835-6100 and have your serial number ready. They will ship it out.
Should take 5 minutes to replace. Yeah a computer tech is quite able.
Aug 22, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Printer error meaning
I found a couple of references to the error ?07,010.43?, it?s a generic message with lots of possible causes. Xerox?s official web site says to turn your printer off a contact their technical support. I did find one reference that said for them it turned out to be a wiper assembly stuck between the print head and the roller. I?ve never owned a Xerox printer (I?m an HP guy) so I can?t help you beyond that. Xerox?s support site for the phaser series is here: http://www.office.xerox.com/color-printers/phaser-8500-8550/sprt-enus.html
Dec 04, 2006 | Xerox Phaser 8550DP Printer
k24674
jasbo
jasbo
