SOURCE: microsoft wireless optical mouse
you have two micro switches that wear-out quickly. try going to. Control panel. Click on Devices. Then on Mouse try switching your right button to left button on button options. try hitting restore defaults. Make sur your remote sending unit is plugged in and the lie is on steady. good luck Joe_Rex
SOURCE: microsoft wireless notebook optical mouse 1024`
I have a Microsoft wireless optical mouse 3000. There is a silver button on the end of the mouse that usually faces you when using the mouse. Press that silver button- while holding the button in, use your fingernail or something to help with gently lifting the main panel on the top part of the mouse. Lift up on the end of the panel that is closest to the silver button. The panel comes entirely off, revealing the inset battery. It took me a while to figure it out since I installed the first battery.. it has lasted over a year. Hope this helps with yours. Have a blessed day!
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
SOURCE: Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
SOURCE: microsoft optical notebook mouse 3000 battery change
Simply push the silver oval button below the word "Microsoft" and the cover will spring open.
