if you have access to a car ramp the oil plug is located on edge of the oil pan and while under your car you will see the oil filter it all depends on what kind of oil you want sometimes it boils down to budget but remember you get what you pay for
locate the oil plug, under car. put pan under it to catch the oil.remove oil plug and let it drain. when all oil is out, replace the oil pan plug that you took out.after doing this remove the oil filter and discard it. put on new oil filter and tighten as much as possible only hand tight. then put in the new oil. check for leaks, and thats it. good-day !
Your bike takes a little over 4qts of oil. The engine drain plug is located on the lower left front of the motor. The oil tank drain plug is located on the bottom of the oil tank, on the right side of the bike. When refilling, put in about 2.5 quarts of oil in the tank and start the bike and run it for about minute and blip the throttle a few times. Then add the remainder of the oil. Run the bike to operating temperature (approximately 15 min) and allow it to idle for about 3 minutes. Then check the level after a minute or so and adjust as necessary.
I recommend VERY Highly that you get the Haynes Repair manual on the vehicle. It will provide Step by step instructions for basic stuff like Oil Changes and Tune Ups and the intervals for these. As for you question. The oil Drain plug is located on teh oil pan at the bottom of the vehicle, The oil Filter is located on the Firewall side of the engine, and other than understanding how to properly install an oil Filter and to use the correct oil there isn't much to it. Oh, the oil drain plug should be a 13 or 14 mm.
well the drain plug is ALWAYS gonna be on the bottom of the oil pan bolted to the bottom of the engine, the filter is either gonna be on the oil pump near the oil pan or it will be screwed into the side of the engine block, either way you should be able to see it just from a quick look from underneath the car.
P0118 - Replace Engine coolant Temperture sensoe located by thermostat housing (upper ragiator hose connects to) sensor is 1 where wire loom lays nect to valve cover.
P0301 - bad spark plug/wire, remove #1 cylinder plug wire inspect for oil on wire (if have oil on wire, valve cover gasket leaking, needs to be replaced) if no oil, inspect plug, replace plugs if needed.
P0705 - bad neutral safty switch (Transmission Range Switch) located on Right Side of Automantic Transmission (by shifter cable)
manual transmissions have an oil drain plug located at the bottom of the trans case and a fill plug located on the side, remove fill plug (side) and oil level should be right at the same level as the hole, just running out
It only has 1 oil pan which is call a dual resreve. One oil plug is a the bottom of the pan the other is at the front of the oil pan. Look at the front of the oil pan for the other drain plug. Make sure on how many quarts of oil it takes. ( I know 5.0 take 5 quarts including oil filter. But then again its a van double check)
