Question about Sharp AL-1000 Copier
I have a Sharp AL-1000 copier and I am getting a flashing error message - the sympol is an 8 with a V looking check right next to it. The copier is very old and I do not have a manual to verify. Changed the toner cartridge but the error does not go away and I cannot make copies
    President:
  • Sharp Master
  • 990 Answers
Hello sir; that symble means paper jam, check the paper path does there have any paper chip stuck inside or the senser out of track.
Posted on May 09, 2009
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
It is a Sharp al 1000 with error message L6 which means Polygon mirror motor not up to speed? How is this fixed and what cost?
Since the polygon motor is part of the laser unit, it would cost about $200 plus labor to replace it
Jun 14, 2010 | Sharp AL-1000 Copier
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
Repairs of sharp AL 1000
Sounds like the scanner is locked. Look under the scanner where the paper comes out, there is a clear wheel, turn it all the way one way or the other and that will unlock the scanner.
Oct 21, 2009 | Sharp AL-1000 Copier
Have an AL-1000. got a crunching noise on start.error message flashes L4..motor drive error?
You most likely have a problem with your fuser rachet dive gear or it could be the upper fixing roller drive gear. I would first look to see if any of screws are lose that hold the fuser in. It could be just from wary and tary on the fuser or it could be that the lower fixing roller is damaged. If your copier has over 50k on it may just be easier to replace the whole fixing unit. Good Luck
Aug 10, 2009 | Sharp AL-1000 Copier
PLEASE HELP ME
you have to reset your drum counter in the maint mode. do you knoe how to get in the maint mode?
Dec 10, 2008 | Sharp AL-1000 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
Nov 19, 2007 | Sharp AL 1631 Copier
Sharp AL-1000 Copier Logo
152 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
