Question about Level 9 Sound Designs Monsoon Planar Media 9 Speaker
Looking for a control pod.
My control pod is no longer working.  I liek these speakers though and would pay for a new/used control pod.
  • 2 more comments
  • sdow Nov 09, 2007
    I, too, am searching for a replacement control "puck". The plug on ours has been literally torn off by careless handling.
    Steve
  • Anonymous Nov 19, 2007
    The plug on my controller has also been torn off when carelessly moving the system around. I like these speakers and would like to replace the controller. Any ideas?
  • penguin478 Dec 19, 2007
    1-877-722-8346 is monsoon number and it is busy. www.monsoonaudio.com is their website and it is unavailable.
    I too need the controller.
  • mwatsous Jan 27, 2009
    My kids snapped off the controller plug at the point where it inserts into the subwoofer. I was blaming my kids, but it sounds like the same problem everyone else is having. Have yet to find the replacement part to order.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Posted on Feb 04, 2008
  • fleetchief Feb 09, 2008
    Further to my earlier post. Ideally you will also need some heatshrink tubing to slip over each lead BEFORE you solder it. (8 pieces 5mm long) Then slide the tubing forward, to cover the pin, and use the heat of the iron to shrink the tubing. I used 2mm tubing but 1mm would be better. (They gave me the wrong size!)
    Start with pin 5 (the middle pin) as this is difficult to get to if you start with the outer pins. If you apply the iron too long, you will find the pin will move one way or the other. This will mean it will have difficulty in fitting into the socket on the back of the bass speaker. The best thing to do is to spend an extra $3 and also buy a 8 pin Mini DIN socket, and keep the plug plugged into that while you solder. This ensured the pins staying straight.
    Another problem I found is that the plugs, available in stores, tend to have a larger outside diameter rubber cover, which may not fit into the recess on the back of the bass speaker. Check before assembly and if necessary widen the access hole for the plug.
    MOST IMPORTANT - Do NOT forget to put the outer rubber cover on the lead BEFORE you start soldering the leads to the pins.
    For extra strength you can use a mini-hot melt glue gun and fill the metal cover (from the rear) before sliding the rubber cover over. The glue is not hot enough to melt any of the insulation on the wires but the tip of the hot-melt glue gun IS, so be careful.
    My system is now working a treat. Total cost less than $5 (I didn't think to buy a socket at the same time as the plug).
    Ed
  • karen osswald Dec 06, 2012
    can you repair mine?
    Problem Solver:
  • 5 Answers
Try ebay.
Posted on Apr 29, 2008
  • 3 Answers
Same
Posted on Jan 02, 2008
SOURCE:
Sound is coming out of only one speaker, with both wires plugged in
have same problem - swapped speaker leads and sound comes out of other speaker
Feb 12, 2010 | Bose Companion 3 Series II Multimedia...
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
Feb 26, 2009 | Logitech Z-5500 Computer Speakers
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
07 jeep wrangler
I wouldnt worry about the dash speakers. Leave them in there and Pod out your doors. They are hidden in the dash if I am not mistaken. I know with Jeeps its hard to install speakers in the dorr as they are so shallow. Use big back fill, to compensate for no sound in front, or buy some Kenwood 3 ways, they are the shallowist you can get. You will still have to pod the door though.
Dec 09, 2007 | Car Audio & Video
5500 d Control pod
Hi Hlth501
So far, is better to get a new control pod. Call the company and see if work for buy it
Nov 25, 2007 | Audio Players & Recorders
Control Center
Same boat. when I call the 1-877-722-8346 it is busy and the website www.monsoonaudio.com, it is unavailable all the time. anyone have any ideas?
Oct 17, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Level 9 Sound Designs Monsoon Planar Media 9 Speaker Logo
1,293 people viewed this question
Top Level 9 Sound Designs Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Level 9 Sound Designs Audio Player and Recorder Expert? Answer questions, earn points and help others
