No display The display on my Tochiba SPM30 Has gone off, I can't get a display through the TV either, have i turned it off by accident ?, if so how would i turn it back on ? Hope you can help
  • tgilliland May 09, 2009
    there are no leads its a laptop!
  • Justyn Feltham May 11, 2010
    If you look at the back of your computer is the lead going from the monitor to it at the bottom(a video add-in card) or the top of the unit(onbard GFX)?
    Problem Solver:
  • 8 Answers
When you turn it on do you get a POST or a Startup screen at all? If so do you know how to enter the BIOS and check if it has a graphics card or on-board GFX? If it's on-board you will have to get it checked by a pro as it could be the chipset or the GFX chip that has failed. The system boards are not cheap even to buy on eBay so it might not be economically viable to fix. If you're confident enough the only thing you can do is a trouble shooting session. First ground yourself by touching a radiator pipe or something that is earthed and without wrenching take out the RAM(push out the spring clips), clean the connector strips and blow out the slots. Replace and try to boot(its amazing how RAM can play havock with a system). If you have no joy with that you will need to take the video card out(if it has one) and do the same with that, be careful though, some GFX cards use the CPU heatsink as the cooling device and you will need new TIM(thermal interface material) for both. If still no joy take out the GFX card and revert to on-board graphics through the Bios if possible(most don't have on-board GFX). If you still can't get it to work then then that's about all you can do yourself without help or spending money. You either need a friend that doesn't mind messing with his laptop so you can try your card in it or take it to a repair shop for testing.
Posted on May 09, 2009
Tengo este mando pero no se como programarlo para un tv tochiba
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Nov 27, 2015 | Televison & Video
Codigo control oasis rm-9513
Nececito codigo de Panasonic tv lc
May 19, 2013 | Televison & Video
I can't hook up my sony wireless headphones to my new tochiba tv
there is no headset jack on the Toshiba 46g300u. It is a bummer. If you add a sound system for $200 bucks or more, they usually come with a headset jack. I sure wish this tv came with a jack, I mean, how can it not?
Jul 05, 2011 | Toshiba 46G300U TV
I have accidently gone past the automatic tune function when 1st turning tv on . How do I manual tune?
I think you mean perform the channel scan function. Every tv manufacturer has different wording in the menu, but basically this is what you would do:
Press Menu, then go to Setup or Installation menu (wording depending upon mfg).
Select antenna or cable (wording could be air or cable)
Perform channel scan
Hope this helps as you didn't mention model.
May 17, 2011 | Televison & Video
I want get drivers for toshiba spm30 <VGA and LAN>drivers
look up your local domestic refrigeration company they should be able to source the parts for you.
Jun 30, 2009 | Heating & Cooling
On Screen Clock Display
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results.
Nov 28, 2008 | JVC AV-36D503 36" TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Locked out TV Screen by accident
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
Jan 25, 2008 | RCA TruFlat 27F520T 27" TV
Pltv3250
do you get audio but no video? if the blue light is not glowing on the power supply.... its gone bad... the vents tend to clog with dust, overheat and burn out In 2 1/2 years I've gone thru 2 of them
Sep 06, 2007 | Protron PLTV-32 Television
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
