Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Can't type name in addressbook on my tracphone
Only gives me the first letter of the number I touch.
  • 20 Answers
Yup, that's all you're ever gonna get.
Posted on Feb 03, 2010
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
How do you add to existing contact list
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again.
You will see the message Successfully Added and you are done!
Jan 04, 2011 | One Touch Jitterbug One-Touch Cellular...
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
How do i add phone numbers
Once done, press YES again. You will see the message Successfully Added and you are done!
Oct 21, 2010 | One Touch Jitterbug One-Touch Cellular...
How do I input an address to get the directions
Touch the MAIN MENU in the top let corner.
Touch the ADDRESS option.
Touch the CHOOSE option.
Enter the name of a State or Province and touch DONE.
Use the keyboard to enter a City or Zip. Once the unit has determined the city, it will prompt you to enter an address. The unit will sometimes provide a list with more than one address that closely resembles the one you entered.
Scroll through the list of addresses provided by the unit and make your selection. When an address is selected, a dialog box will appear with three choices: Add to Addressbook, Find on Map and Go To.
The ADD TO ADDRESS BOOK will add the address to your list of contacts in the Address Book.
FIND ON MAP will show you that location on the map screen.
GO TO will start navigating you to the location and begin giving turn by turn instructions.
Jul 09, 2009 | Lowrance XOG GPS Receiver
Recover a contacts from a formated cellphone memory
i lost my contacts from my phone memory in nokia 5310 pls help me to get the contacts
Apr 24, 2009 | Nokia 5310 Cellular Phone
Can't see addressbook name when i receive a text message
That means that there is a double entry. the number saved in your address book has eitehr been saved twice or saved twice with different names. Delete the entry in the address book then turn off and on your phone. you should see the name of the other entry now.
Jan 05, 2009 | LG Shine KE970 Cellular Phone
Voice Mail Problems
These voice mail systems aren't looking for letters on the Treo keyboard...they are looking for numbers on a phone which have letter equivalents. This is hard to do on a Treo, since the letter equivalents are not written on the phone. Look at a standard desk phone:
2 = abc
3 = def
4 = ghi
Jun 16, 2008 | Palm Treo 700p Smartphone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Addressbook cannot be accessed on siemens s55
dear u have to make it fulflash take it to a technician.if u r them make it urself.
Jan 18, 2007 | Siemens S55
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
