Question about Microsoft Xbox 360 Console
I have a problem with my 360. i have sound but no view..
Well as i said.. when i start my xbox i can hear my profile log in but the screen stays black.. i tried to start up the game but it doens't work.. and i disconnected the wires and plugged them in but that also didn't help.. so.. what could be the problem and how do i solve it?
Send it in, i just got the same thing. its hardware failure...
Posted on Oct 17, 2007
You might have your three componet cable things (red white yellows) switched to HDTV. On the opposite end of the cables you have the thing that plugs into the 360 just switch it to tv and it should work fine.
SOURCE:
I clicked an update for Dance central on xbox kinect and now all my points and achievements have disappeared
Your xbox probably logged your profile out. Log back into your profile and your info should show back up.
Mar 15, 2011 | Microsoft Kinect Dance Central D9g00024...
My xbox 360 dosent want to update
The new update for 360's launch of Kinect is causing problems. I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
Nov 01, 2010 | Microsoft Xbox 360 Console
I try to log on but is says that i need an update but i can't my connections is bad and it keeps saying to check my connections
The newest update for Xbox 360 for the launch of Kinect is causing problems. I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
It wont let me download the update
The new update for the launch of Kinect is causing problems. I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
Nov 01, 2010 | Microsoft Xbox 360 Live 12-Month...
When i boot my xbox up the tv will stay blank but i will hear the sounds that it usaully makes when it logs into my account
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Jan 23, 2010 | Microsoft Xbox 360 Console
My xbox turns i hear the log in sounds but it stays blank.
try a different input on your TV or replace the AV cables
Aug 01, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
Save device error
What save device are you using? memory card or hard drive?
It sounds like whatever you're using has started to malfunction. Are you able to pull up other save games?
Note that saved games are associated to a unique profile on the device, even if you're not on Xbox Live. That is, if you were logged in as profile "tools" when you saved the game you have to be logged into the same profile to load the game.
Nov 17, 2007 | Microsoft Xbox 360 Console
Xbox 360
Check your AV cable if your tv is HD push the tab to HD if not set it to normal tv this should help you out. If that doesnt work i would try to borrow someones AV cable and try that.
Nov 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
