Question about Christie ROADIE X10 Multimedia Projector
Our x 10 will not fire 20 min till show please advise
  • 2,237 Answers
The power supply has dried caps that won't charge as fast as they used to, or hold that charge. you'll need to replace the power supply.
Posted on Feb 04, 2010
The furnace fires up 9 out of 10 no problem. when it doesn't for the pilot lights up for a second then cuts out. There is a click every time and it will continue to do this till it finally fires up....
I can't tell by the picture your showing if it's a mid efficiency or the pilot stand by if it's mid efficiency furnace then there's a reset button if the other it sounds like your high and low limit switches are not in sink to each other ,should be able to find out how to set on the internet if not that then check your thermostat
Feb 12, 2015 | Heating & Cooling
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
98 SUZUKI SAVAGE
is it ECU or coil plug fired, could be coils over heating. if injection????
Jun 22, 2014 | Suzuki LS 650 Savage Motorcycles
99 neon: random misfire-error code 43-runs choppy-poor gas mileage
No Engine I know of has a 1,2,3,4, fitting I am sure you have the firing order connected wrong, plus your description point to the firing order as well. Cheers, Malcolm Campbell.
Apr 18, 2017 | 1999 Plymouth Neon
My problem is? I ll start my truck when its cold and it will fire right up, will drive it till its good and hot then when i shut it off for about 15 to 20 min. and try to start it , it will turn over but...
sounds like it is vapor locking. I see this a lot with Fuel injector Carb units. It is usually a leak on a gasket in the Carb or on a flexible fuel line causing the problem.
Feb 05, 2011 | 1993 Toyota Pickup
1987 Buick Park Avenue
ign.modulator inside the dist.cap
Oct 21, 2008 | Buick Park Avenue Cars & Trucks
Heating up..clothes not getting dry just warm and damp
the valve coils??? ifyour burner is firing ,the heat cycle is good, but yes it is possible that the coilsheat up after being on for 20-30 min adn then willl stop opening the valve thus no dry..
279834 set of valve coils, unplug the unit and remove the 2 philips screws holding down the set on the valve, easy repair, cost you about 20 bucks for the set.
UNPLUG UNIT BEFORE SERVICING
Apr 03, 2008 | Whirlpool GGW9200L Gas Dryer
46 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
