Question about Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel XTI will not turn on. I replaced the battery, but it still won't turn on.
  • chelseacat May 09, 2009
    Mine has the same problem, but If you take out the memory card and see if the pins are turned over, that may be the problem, that is what is wrong with my camera, I have not yet figured how to take it apart and fix it, or if you have to send it to canon...
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
Could be a blown fuse. There is some help here, if you are OK taking your camera apart - but read the entire thing before starting!
http://users.abo.fi/jskata/300Drepair/
Posted on May 11, 2009
5 Suggested Answers
SOURCE: canon rebel xti digital camera
Clean the Camera and Lens Contacts
Posted on Sep 23, 2008
SOURCE: My canon Rebel XTi keeps
I just called Canon because I was having the same problem. They suggested putting the camera in the sports mode. The reason it flashes busy is because there is a buffer period after taking pictures where the camera needs to store the information to the disk or if using a flash, then the flash needs to recharge. If you have plenty of natural light, then the full auto (the green square) mode can be selected because the flash won't have to recharge. If you are using the portait mode, then you will have to wait for the buffer period for the flash to recharge and the information to be stored to the disk.
Posted on Apr 11, 2009
  • 164 Answers
SOURCE: canon rebel xti says cf
Check with a magnifier and a flashlight the conditions of the CF memory reader pins. Usually this kind of cameras have the common problem of have bent or broken the CF reader pins. This may caused the original CF error. If you tried to format a CF memory card, then the bent or broken pins may caused the Error 99. By the way, error 99 is applicable to a very open range of problems (lens contacts, faulty shutter, CF memory card access errors, etc). If is under warranty your camera, once you confirm the reason of the problem, send it to Canon for repair. If is out of warranty, you need somebody to repair it, which is not easy for the common person. If need help on repairing it, please contact the ID user Great_items_2004 at ebay. Regards and good luck.
Posted on May 01, 2009
SOURCE: The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Posted on Sep 16, 2009
Canon rebel xti
Tr5y a factory reset on the camera. And try another Memory card.
Aug 19, 2014 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Canon Rebel EOS T3 that won't turn on, even when the battery is apparently "full". What could be the problem?
Yes, it could be an issue with the camera or the battery. The easiest way to find out is to try a different battery in the camera. If this works then the most likely culprit is your battery. If this doesn't work then your camera requires service.A good camera store should let you try one of their batteries in your camera.
Apr 22, 2012 | Canon EOS 400D / Rebel XTi Digital Camera...
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS rebel XTi won't turn on. Changed batteries several times still nothing
Mcm,
Trying taking a Q-tip with some alcohol and cleaning the contacts inside the battery chamber. Also, you can take it to your local camera store and ask them to try it with one of their batteries to rule out if yours is dead.
Thank you.
Mar 28, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
My canon rebel xti will not turn on. I have replaced all the batteries, and still nothing starts up.
There could be dust or other foreign objects in the battery slot, you might need to clean it out. If not, I would advise that you may need a replacement battery
Mar 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Oct 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
3,846 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
