Question about Kenmore HE2 Plus Front Load Washer
F-21 on my window
F-21 comes up on my washer window.I have a load of clothes in the washer with water in it but I cannot get the washer to go.It's like she is ceased up.
  • Susan Dobrunick May 13, 2009
    This is problem I am having. Although my manual says its a drain problem, we can't figure out why. Our drain hose is not kinked, frozen or clogged and it is more than 96" above the floor. I will get this problem all the time. Sears is taking a week to get here to look at it!!! That is forever for a family of 4 to go w/o washer. I am very dissappointed in Kenmore and Sears....
  • 460 Answers
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
Posted on May 13, 2009
Samsung washer gets clothes dirty
Put a whole house water filter on the cold side of the inlet water. I bet you have well water with lime in it??? Wash your clothes only in cold water. Rub a couple of empty loads with clorox, lime away, oxy clean to remove any build up in your washer
Oct 21, 2012 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
Washer not spinning properly
Hi, there may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out. Reconnect and try again.
Jul 13, 2010 | Asko W6021 Front Load Washer
Regarding the kenmore he2 plus front loader washer.f-21 keeps coming on.actually worked for a couple loads today but f-21 started coming on again after i started washing a 3rd load of colored clothes.seems...
There is a strainer on the drain pump that is clogged. The manual does not mention this at all, it merely states the drain hose is kinked or clogged.
Under the front door there is a panel that is the width of the machine and is held in place by two screws, one on either side.
When you remove that you will see the pump and the the strainer attached to it. Unscrew the strainer (put a small pan under it to catch excess water) and remove to remove the junk accumulated.
Also, attached to the panel is another manual that refers to the error codes you are seeing.
Dec 20, 2009 | Kenmore HE2 Plus Front Load Washer
Small cloths are going between washing drum and
you nead to be aware that when you put clothes in your washer you have to understand that you only put cloth's in that you do not have push down.if yopu over load your washer,the water will come in and the cloth's will rise faster than the water come's in,that will alow cloth's to get into the outer tube and block your water pump.
Oct 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Makes a grnding sound when washing(not always) & does not spin all the water
This problem happen to me a few months back--washer was 6 months old. A technician came out and told me that I must have loaded the washer after the water was in the tub. He stated that I must load my washer prior to running the water in because the water fill amount is based on weight; therefore it was now weighing too much. Go figure...have always loaded the washer with water first and clothes last. I always put clothes in first then the water--I must say, the problem has not reappear.
Hope this helps.
Nov 03, 2008 | GE Profile WPRE6100G Top Load Washer
My washer keeps flashing f-21 and water coming out, I took some clothes out than started a new load a smaller one and now it will not even run. HELP!!
if you take the screws off of the foot plate and remove the foot plate on the back is a plastic bag where the codes can be found..... both washer and dryer are located there. good luck.
f21 long drain.
Aug 08, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Kenmore HE2 Plus Front Load Washer Logo
437 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
